Question about Car Audio & Video
Maystar mcd303rds HELP!! Maybe the wrong place to ask, if so many appologies for wasting your time, sorry! but....just fitted the above and it keeps going to ...PHONE IN ....and cutting the output. does it at random times .There is no [as far as I can see] any in car phone kit fitted anywhere. Just bought the car, it is an N Reg diesel Astra Estate for work. All help appreciated, many thanks
  • trimixdiver Dec 11, 2007
    I decided in the end to go back to basics. I got a lead which splits the connector into 3 seperate items. Ignored plug 'C' that is the "odd" stuff. Plug 'B' speakers and Plug 'A' . just used the perm feed in, switched feed in and the ground. Did not even bother with aerial feed. Worked first time!!
    On the Astra there were loads connected to the plug, some had 2 connections. Something to do with the OEM on dash display for the original radio I think. All works now apart from the very occasional loss of volume when switching the engine on!! I can live with that though. Thanks for the input, I have stuck a note to the bottom of the unit so that when I refit it next time I have a chance
    Thanks
    " Dive long and prosper "
I have just had the same problem. I have a N reg vectra and just fitted a Maystar radio. I too was getting the PHONE IN message randomly when the ignition was on (fine when not).
I think the PHONE IN is a mute function to cut sound when a call comes in. On my connections it was the brown wire - it should tell you the "Phone in" connection in the manual or on the bottom of the radio. I disconnected this and taped up with insulation tape to avoid connecting with anything else. Worked for me!
Posted on Dec 10, 2007
Who do i speak to about urgent financial assistance
Financial Assistance Information ..i live in the uk so i dont know if i have found what you are asking for,i hope i have if not i am sorry for wasting your time.click on the link above.
Nov 28, 2016 | Cell Phones
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
Oct 02, 2008 | Samsung CLP-500N Laser Printer
Tried to tighten belt on my sofetail harley but adjustment bolt are all the way in but there's more room to go can I get a longer adjustment bolt or make one
you probably get longer bolts but I would be asking why you would need them
maybe the belt is stretched or the wrong size belt is what i would be considering. have you had the bike all the time ,if not was a different wheel pulley fitted at some time making the belt the wrong size
did the adjusting bolts break at some time and the wrong bolts fitted
May 24, 2015 | Harley Davidson Motorcycles
How to install maystar s20/50
Maystar s20-50 connections.
Red + to permanent supply via 15A fuse
Black - vehicle body earth wire
Pink - negative trigger input, connect to additional earthing (pin) switches for bonnet boot etc.
Violet - for connection to negative switched courtesy light door switchs
Blue - ACC wire connect to an ignition switch positive supply
Yellow- connect one yellow wire to the left indicator and the other to the right inicator. Ensure that you connect to the switch output to the bulbs, not the supply to the switch.
White - Current sense loop- cut for current sense leave intact for non current sense.
Green - Antenna wire must not be cut or terminated.
Quick connect, for connection to additional Maystar control modules and sensor systems, follow the instructions supplied with the additional sensor.
Jan 16, 2013 | Cars & Trucks
Epson workforce 1100 printer's ink pads are at the end of their service life
please clean ink pads place and re install in pads and solve the problem
May 07, 2012 | Epson Printer
Water is on the floor underneath the washer
have you checked the water fitting at both ends if they are dry and both tight look at the waste connection i would advise getting PTFE tape for screw fittings any diy store will have it just ask, but checking that all fittings are tightly done up and hoses aren't broken it might be seals inside the washer that might be worth getting someone to look at sorry cant be any more help.
Apr 09, 2012 | Whirlpool Duet GHW9150P Front Load Washer
After asking 2 questions and getting 2 stupid answers, I wonder what is answering them. I MENTIONED NOTHING ABOUT BURNING CD'S< WHAT I WANT TO DO IS FIX MY DVD/CDPLAYER WHICH IS NOT RECOGNISEDB
Maybe i can help you will need to go to device manager then check dvd cd rom drives if it shows anything right click and select update driver if that does not work try uninstalling the driver and using it as a default drive which will work the exact same way hope this helps sorry for all the wasted time other people wasted =]
Mar 04, 2012 | Computers & Internet
After starting the laptop and then placing Norton 360 version 4.0 inside the disk drive, the laptop asks for a product key. After the product key is correctly entered, the laptop restarts again. When this...
Hi....
Sorry to say norton is a waste of time and system resource,s...
I run a computer business..and i would reccomend deleting norton,and choose avast...it,s been rated 1 of the top antivirus,s and it,s free....
Hope this helps,if so please rate this as i,ve taken the time to answer you,if i can be of any more help..
Regards
Apr 02, 2011 | Computers & Internet
How do i replace the waste toner box on the konica minolta
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Jul 31, 2008 | Konica Minolta Office Equipment & Supplies
Canon printer i 475D
This may be worth a try
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Jun 28, 2008 | Canon Office Equipment & Supplies
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
