Question about Jamo Audio Players & Recorders
I have a Jamo 360 series soundbar. Its been in storage for about a year and half. I brought it home and everything seems to be working fine other than Im getting no sound when I hook it all up.
SOURCE:
SOURCE: no sound from my clarion vrx755vd
I have a 7in in dash dvd player but it does not want to play cds or dvds. it gives me an error notice. it won't even eject the cds. Where can I fix it?
Thanks
Posted on Jan 08, 2008
  • 6 Answers
SOURCE: NO SOUND
First, rule out problems with the wiring to the speakers. Disconnect the speaker wires to the amp. Get a AAA battery. Hold one of the wires to the negative side of the battery and lightly grace the other wire across the positive side. You should be able to hear something like pops and scratches coming from the speakers. Do this for all the speaker wires and wire-tie each pair.
Posted on Nov 15, 2008
  • 29 Answers
SOURCE: i have an panasonic toughbook
Use the following link to download new sound drivers.
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Posted on Dec 14, 2008
smarthome2
  • 1114 Answers
SOURCE: Sony HT-CT100 soundbar + STR-DG720 = Yes misery, no audio
It's not going to do whayt you want. On the premise that you can't run a dedicated receiver to a dedicated receiver. One processor is not going to override another. The soundbar is a "self contained" closed system. Much like Bose products. I understand what you are looking for, it just can't be done with this product. Options: replace the sony soundbar with a passive polk soundbar or similar and keep the AV receiver or: Return the AV receiver and use the nice, but limited sony amplified soundbar. Hope this helps
Posted on Jun 25, 2009
bozcro
  • 867 Answers
SOURCE: Everything seems to run fine, just hasn't pulled a drop of water
remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
Posted on Jul 22, 2009
Replacement remote for Jamo 360 soundbar
Amazon.com: Replacement Remote Control for JAMO TORSTEN 360 ...
https://www.amazon.com/Replacement-Remote-Control-JAMO.../dp/B01E67NI6U
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. *This is NOT an original JAMO remote ...
Replacement Remote Control for JAMO TORSTEN 360 ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls US$38.81 - ‎In stock
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. This is NOT an original JAMO remote ...
jamo replacement remote ' AVForums
https://www.avforums.com > ... > Home Cinema Speakers Oct 5, 2014 - Hello, I have jamo p102 speakers. Unfortunately the remote is broken which means I can't control the speakers at all now. It can't be fixed. Is it... Replacement remote for Jamo 360 soundbar Google Search
Feb 01, 2017 | Jamo Audio Players & Recorders
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Hammond organ, L series brought out of lomg term storage problem
Lubricate with OFFICIAL Hammond oil immediately! Then let sit for a couple weeks. Manually turn the generator and add lube as needed until free. If bearings still sticky, put a bit of CRC226 on them individually and free them, then lube with the hammond oil via the wicks.
CRC226 is available at Home Depot in electrical dept.
Also, go to the organforum.com for additional help.
Jan 24, 2010 | Music
Just like everyone...came home all of a sudden the unit won't turn on ???? standby light is on but nothing..
In addition to just unplugging the unit, another method that worked for me when unplugging it did not was to unplug the HDMI cable from the TV and then unplug and replug.
Jan 03, 2010 | Philips SoundBar DVD Home Theater with...
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Nov 04, 2009 | Samsung HT-X810T Theater System
Jamo DVR-50 Problem
had same problem told power supply unit is u/s £153 all in to fix it , gonna get new player , other probs telephone Telefringe 01373 462598. hope this helps someone.
Nov 22, 2007 | Jamo DVR-50 System
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
