Question about Toshiba Wireless Mouse PA3205U-1ETC
Put USB receiver in mouse and can't get it out.
Put USB receiver thing in receptacle of wireless mouse model N745 and can't get it out. What's the trick to get it back out ?
Push the back of the middle top center strip down and it should pop out!
Posted on Aug 03, 2009
  • 724 Answers
There is no trick no latch nothing did you force it in it does not go in backwards or I should say upside down...maybe the white tong in the socket broke and is wedged in there. never see that happen but anything is possible
Try pushing it is and wiggle it like a car key to dislodge it as you try to pull it out very gingerly does it work leave it there if it does. Consider it part of the permenant furniture
Posted on Aug 02, 2009
How do I install wireless mouse on my virgin telly tablet
Wireless mice come with a wee USB transceiver. You should be able to find one for U$20 or less for the least expensive model.
If Android 6.0 Marshmallow supports USB mice (which is the OS the Virgin Telly site says is running your unit), all you need to do is plug the transceiver into one of your USB ports, put batteries in the mouse, and start mousing it up. :)
I'm no Android expert, so I can't speak to the particulars of your OS, but normally an OS will tell you that it is installing a device when you plug it in for the first time.
Cheers, and good luck!
Nov 22, 2017 | Computers & Internet
Where is the receiver or usb device in a GE wireless optical mouse 98763
There isn't one on a wireless mouse.You get the sender with the mouse that goes into your USB port on computer.Put it back together and find the little USB sender in the blister pack,put a battery in the mouse,and your good to go.All i use is wireless mice.
Nov 08, 2013 | GE Optical Mini Wireless Mouse 98793
The red laser pointer underneath the mouse isn't coming on? put new batteries in and the receiver is showing the green light once plugged into my laptop.
I doubt the problem is the battery. I have this same mouse and it has worked beautifully for two years now EXCEPT for one problem: most of the time, the mouse does not turn on when the receiver is removed from the receptacle on the bottom of the mouse. There is a tiny little switch built into that receptacle, along the side wall of the receptacle not far from the light. I have to wiggle this little switch (gently!) by hand a few times until the light comes on. From that point, the mouse will work fine until the receiver is placed back in the receptacle.
Dec 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
Acer N745 stuck
The top should have a button to release the receiver (on the lower half). If pushing this does not release it, you can disassemble the mouse fairly easily (you do not even have to break the warranty seal). Removing the cover to install batteries, you should see two screws. Remove them. on the bottom, underneath the upper-left corner of the "Acer" sticker is the third screw. Once disassembled, if you look at the top, you should see two white "tabs" that when depressed should release the receiver. If this still does not release it, you can then remove the bottom half of the mouse and then lift (since it's inverted now) the tabs. Hope this helps!
Aug 27, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Toshiba N745 USB Adapter Problem
there is a button just behind the scroll wheel, push it and the usb unlock and come out.
May 31, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
There should be an eject button on the lower portion of the mouse. Press that button and the receiver can be removed.
Hope this helps...please share your experience by voting on this solution.
Mar 28, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Can't open toshiba wireless mouse to change batteries model n745
if u look seriously. you can get above side is two part and below side is one part, press above scroll ,'againast side of the cover and pull (there is a plastick lock.)
Toshiba wireless mouse cursor not moving!
Try replacing the batteries or if it has rechargeable batteries, try removing and replacing them. Also clean the red lens on the bottom of the mouse with a cotton swab. Good luck!
Mar 14, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Forgot how to turn on wireless mouse
Plug in the USB. Look under the mouse for the select button to the "on" position. Ensure batteries are good.
Please rate this solution.
Jan 09, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Toshiba Wireless Mouse PA3205U-1ETC Logo
235 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
