Question about Samsung SGH-e315
I put a code on my phone and can remember the code i put.
Its an LG phone with an lithium ion battery 3.7 v. its small and silver and my code is four digit numbers.
    Problem Solver:
  • 5 Answers
Here's samsung codes for you
hope they help as u didn't say which "code" you entered
halfway down is the code you maybe looking for underneath the *****Warning*****
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error Menu
*#8999*327# EEP Menu
*#8999*3825523# Don't Know.
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
#*4773# Incremental Redundancy
#*7752# 8 PSK uplink capability bit
#*7785# Reset wakeup & RTK timer cariables/variables
#*1200# ????
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*#8999*324# ??
#*7828# Task screen
#*5111# ??
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen
#*3849# Restarts Phone
#*3851# Restarts Phone
#*3876# Restarts Phone
#*7222# Operation Typ: (Class C GSM)
#*7224# !!! ERROR !!!
#*7252# Operation Typ: (Class B GPRS)
#*7271# CMD: (Not Available)
#*7274# CMD: (Not Available)
#*7337# Restarts Phone (Resets Wap Settings)
#*2787# CRTP ON/OFF
#*2886# AutoAnswer ON/OFF
#*3737# L1 AFC
#*5133# L1 HO Data
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*7284# L1 HO Data
#*2256# Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*4700# Please use function 2637
#*7352# BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
#*2558# Time ON
#*3370# Same as 4700
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5187# L1C2G trace Activate/Deactivate
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*7524# KCGPRS: (FF FF FF FF FF FF FF FF 07)
#*7562# LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*5171# L1P1
#*5172# L1P2
#*5173# L1P3
#*7326# Accessory
#*7683# Sleep variable
#*8465# Time in L1
#*2252# Current CAL
#*2836# AVDDSS Management Activate/Deactivate
#*3877# Dump of SPY trace
#*7728# RSAV
#*2677# Same as 4700
#*3797# Blinks 3D030300 in RED
#*3728# Time 2 Decod
#*3725# B4 last off
#*7372# Resetting the time to DPB variables
#*7732# Packet flow context bit Activate/Deactivate
#*6833# New uplink establishment Activate/Deactivate
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*4472# Hysteresis of serving cell: 3 dB
#*2775# Switch to 2 inner speaker
#*9270# Force WBS
#*7878# FirstStartup (0=NO, 1=YES)
#*3757# DSL UART speed set to (LOW, HIGH)
#*8726# Switches USBACM to Normal
#*8724# Switches USBACM to Generator mode
#*8727# Switches USBACM to Slink mode
#*8725# Switches USBACM to Loop-back mode
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*2872# CNT
*#8999*283# ???
#*22679# AMR Get Time
*288666# ???
*2886633# ???
*#8999*364# Watchdog ON/OFF
#*8370# Tfs4.0 Test 0
#*8371# Tfs4.0 Test 1
#*8372# Tfs4.0 Test 2
#*8373# Tfs4.0 Test 3
#*8374# Tfs4.0 Test 4
#*8375# Tfs4.0 Test 5
#*8376# Tfs4.0 Test 6
#*8377# Tfs4.0 Test 7
#*8378# Tfs4.0 Test 8
#*8379# Tfs4.0 Test 9
#837837# error=...
#*36245# Turns Email TestMenu on.
*2767*22236245# Email EPP set (....)!
*2767*837836245# Email Test Account!
*2767*29536245# Email Test2 Account!
*2767*036245# Email EPP reset!
*2767*136245# Email EPP set (1)!
*2767*736245# Email EPP set (7)!
*2767*3036245# Email...
*2767*3136245# Email...
*2767*3336245# Email...
*2767*3436245# Email...
*2767*3936245# Email...
*2767*4136245# Email...
*2767*4336245# Email...
*2767*4436245# Email...
*2767*4536245# Email...
*2767*4636245# Email...
*2767*4936245# Email...
*2767*6036245# Email...
*2767*6136245# Email...
*2767*6236245# Email...
*2767*6336245# Email...
*2767*6536245# Email...
*2767*6636245# Email...
*2767*8636245# Email...
*2767*85236245# Email...
*******************WARNING****WARNING*****************
*2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also changes the IMEI to 447967-89-400044-0, you must use a program called "CHGIMEI.EXE" to restore it)
*2767*2878# = E2P Custom Reset <----PRIVACY LOCK---->
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Posted on Aug 10, 2009
How do i get a voice mail pass code
You set up your voicemail pass code when you first set up your voicemail. If you cannot remember it, contact your provider for assistance.
Feb 03, 2015 | LG Premium-Grade Replacement Lithium-Ion...
Battery
Step 1:
No just the laptop charger needs to be plugged in.
Frequent Charging Shortens Battery Life Frequent charging shortens the life span of a Lithium ion battery. Batteries should be charged only after they expend all their power. b> Switching Batteries Switching batteries helps preserve battery life: If a cell phone or computer user puts in a spare battery while separately charging the primary Lithium ion battery, that helps extend the life of both batteries. b> Removing Batteries Most laptops charge the battery when a user plugs in the AC adapter. Users can adjust this setting by changing the power options. Windows places this option in the Control Panel, while the Gnome Linux desktop places power options under "Administrative Tools". Cell phones incorporate their own power-saving features that the user usually cannot control. b> When to Replace a Lithium Ion Battery If a laptop battery does not hold a charge for more than a few minutes, a user must replace the Lithium ion battery if he wants to use the computer without an AC adapter. b> Other Ways to Extend Battery Life Storing a battery in a cool, dry environment causes a lithium-ion battery to last a little longer and reduces the frequency of needed battery replacements. Battery Bar - Free version available
http://osirisdevelopment.com/BatteryBar/index.html
Problems with power usage and battery life - Mr Fixit
http://support.microsoft.com/gp/windows_battery_power_settings
Feb 21, 2013 | Computers & Internet
Why so long when i'm charging my lenovo a1-07 ideapad
Frequent Charging Shortens Battery Life Frequent charging shortens the life span of a Lithium ion battery. Batteries should be charged only after they expend all their power. b> Switching Batteries Switching batteries helps preserve battery life: If a cell phone or computer user puts in a spare battery while separately charging the primary Lithium ion battery, that helps extend the life of both batteries. b> Removing Batteries Most laptops charge the battery when a user plugs in the AC adapter. Users can adjust this setting by changing the power options. Windows places this option in the Control Panel, while the Gnome Linux desktop places power options under "Administrative Tools". Cell phones incorporate their own power-saving features that the user usually cannot control. b> When to Replace a Lithium Ion Battery If a laptop battery does not hold a charge for more than a few minutes, a user must replace the Lithium ion battery if he wants to use the computer without an AC adapter. Other Ways to Extend Battery Life Storing a battery in a cool, dry environment causes a lithium-ion battery to last a little longer and reduces the frequency of needed battery replacements. Hope this helps.
Dec 29, 2012 | Lenovo IdeaPad A1 Tablet with 16GB Memory...
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Apr 22, 2012 | Ryobi Multi-Volt Battery Charger
I bought the two pack Ryobi Lithium-Ino Batteries along with the six battery Ryobi One + Charger. When I use it on my P201 Ryobi 1/2 Drill and the drill encounters any type of a torque situation the...
I would not say they are not defected, but I think they are not getting fully charged. I have the same problem with my battery once I have used it all day and the red light comes on from the fuel gauge. I have the P104 battery. I would return your charger and try to charge them on the new one first. If you have the same trouble, then return the batteries for new ones.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery goes dead in 1 day
Lithium-Ion (Li-Ion), 950 mAh
Talk-time - up to 240 minutes
It also depends on if you're texting a lot, because with the combination of texting and talking, it really drains your battery. I have almost an identical situation with my Iphone...
Oct 29, 2009 | LG Xenon GR500 Cell Phone
Batterys
  1. Order a new battery. http://www.all-battery.com/ It was LG Li-Ion 18650 3.7V 2400 mAh Rechargeable Battery with Tabs. Original battery is 1,800 mAh so the replacement should last longer.
  2. Take the screen cover (faceplate) off and unscrew 4 screws. You will need small Philips head screwdriver.
  3. Pull off the front of the GPS. Be carefull with the GPS antenna. Make sure you remember its position so it is easier for you to assemble it later.
  4. Unscrew 2 small screws holding metal battery retainer strip. The battery is behind it. Pull battery out and disconnect it from the board.
  5. Cut the heat shrink tube the battery is in and de-solder the joint.
  6. Solder new battery. A small 15W soldering iron will do the job perfectly. Make sure not to overheat the battery.
  7. Insulate the solder joints.
  8. Put the new battery inside a heat shrink tube. You can get it from HomeDepot. It is ¾ inch diameter.
  9. Use a heat source (I used a gas lighter) to “shrink” the tube. Again be careful not to overheat the battery as it may explode.
  10. Put battery back into instrument and screw the metal band back onto the battery.
  11. Assemble everything back together.
*NOTE* Lithium Ion batterys do not take heat well. Leaving your GPS unit on the dash on hot sunny days will decrease its expected lifespan.
Aug 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Samsung SGH-e315 Logo
404 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
