Sometimes users are so confused to buy a domain and web hosting from Host Gator because of high price values but now do not worry we provide HostGator Promo Codes for web hosting and domain with 75% discount, so hurry up and get your coupon fast. https://s3.amazonaws.com/hostgator-coupon-codes-2018/index.html
SOURCE: can not load new mac software
It seems that while installing Mac, you selected a password for admin, and so, before installing any software you should insert the password.
If your Mac has not any admin password, I suggest you that make an admin password and now check to install your software by your new password.
SOURCE: i forgot my administrator password for my mac g3
If you are running OS X put the appropriate system disk in the disk drive. Boot up using the c key. Once booted go up to the file menu and go to the reset password menu and reset your password.
SOURCE: password
hi, i'm new here.i meet the same issue.i forgot my windows administratorpassword a few days ago. quite a headache.
i triedseveral free software. it took me two days and got quite messy. unfortunatelynone of them work for me.finally i made it work with <a href="http://www.password-genius.com/ ">password genius </a>. the goodnews is it works. the bad one is it is not free. try it. you have no need to reinstall your system.
SOURCE: reset administrator password acer laptop 5732z
For your Windows Vista administrator password?
I had also faced the same problem,
I succeed in reseting my Windows Vista password using Windows password Seeker
1.Download Windows Password Recovery from Password Seeker Official site
2.Decompress the Windows password Recovery Tool and note that there is an .ISO image file. Burn the image file onto an blank CD with the burner freely supported by Password Seeker.
3.Insert the newly created CD into the locked computer and re-boot it from the CD drive.
4.After launched the CD, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, you have Crack windows password.
You can try, Good luck!
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
To change the administrator password, you must know the current administrator password. If you're logged in as the administrator, open Account preferences and click the Change Password button.
If you don't remember the password and automatic login is turned off, you can reset the administrator password using the Mac OS X User Install disc.
IMPORTANT: Because a user with the Mac OS X install disc can gain unrestricted access to your computer, you should keep the disc in a safe place.
To reset the administrator password using the Mac OS X disc:
Be sure to change your login password in Keychain Access to match your new password.
