Question about Motorola Mobility RAZR V3
My end button on my razor phone does not work my
My end button on my razor phone does not work my phone is turned off and i caint turn it back on how do i get my end button to work again?
    Genius:
  • 3,422 Answers
HI,
This problem will require a physical presence of a tech.You actually need to unscrew the phone from the back with a set of tools and remove the carbon in the phone.You will then have to clean the keypad with a help cotton and few drops of alcohol.But if you notice any black spots on the keypad that means the carbon has been deposited on it and it can only be removed with a set of special pin link tool.Make sure not to use excess amount of alcohol as it can get into the circuits of the cell phone.So you will have to get it repaired.
And if this phone is under warranty then i highly recommend you to send it to them.If you attempt to fix it yourself then you might end up damaging the circuits which will void the warranty.
If
Posted on Aug 02, 2009
I ride my scooter and then it turns off..the button pops out and when I push it back in it will work for a few moments then stop again.. is the battery done?
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
Jan 11, 2011 | Razor E300s Electric Scooter With Seat
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Dec 29, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Screen is not working; previous water damage. Phone not been same
For the symptoms your are giving, probably the best solution is to get a new phone. Sorry about that
Apr 09, 2009 | T-Mobile Motorola Razor V3 Custom Cell...
Turn it on
You have to hold down the end call button which is a red circle on the right side of the keyboard. Hold it down about 3 seconds and the phone should turn on. Hope I Helped!
Jan 28, 2009 | Motorola Mobility RAZR V3
My motorolav3m razor phone is on the fritz
you need to take the phone to a mobile service center and hvae them correctly install the firmware back on the phone
Dec 07, 2008 | Motorola Mobility RAZR V3
My razor won't stay on!
try a new battery and also take the phone and have the firmware reflash on the phone to correct this problem
Sep 30, 2008 | Motorola Mobility RAZR V3
Has been working fine, now Razor phone cannot find it.
hoping this helps...
Explorer Series: 220,320, 330, 340, 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
The passkey is 0000
Sep 18, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Wont turn off
First, take the battery out and put it back in to reset it. Then try again to see if you can manually turn it off.
This resets the phone and is the first step in troubleshooting.
Another thing I would do, is test to see if there is something wrong with the end button itself. With a flip phone, normally the end button is unneeded because you close it to hang up. Try ending a call using that button to see if it is a broken keypad issue.
I would also have the local store update the firmware, which should repair any files that may be corrupted, if that is the case.
Also, if the phone has any water damage (when you open the back of the phone, there will be a red dot instead of a white one), this can cause all sorts of crazy problems.
If none of the above solutions work, the only other way to power your phone off is just to remove the battery. You should be able to put the battery back in without the phone restarting, but if it does, just keep the battery out when you want the phone off.
Jan 21, 2008 | Motorola Mobility RAZR V3
Wet phon
If the screen is working, your phone seems fine, however, you must take this phone to someone who knows how to open the phone and clean the IC. The drink must have gone inside the phone due to which the keypad is not working. For the iPod, it seems the battery isnt charging anymore. Thats why it won't work when not connected to the power. So, get the battery checked.
Feb 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
141 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
