Question about Sharp AR-5320 Black and White Copier
L and 4 on LCD screen
I started turn it on this morning and there was L and 4 appeared on the LCD screen. How do i solve about this sir?
  • Sharp Master
  • 1,294 Answers
Please turn OFF and On power switch.L4 mechanical problems(motors).
Posted on Aug 02, 2009
Please help me with my canon ir 2520 error code e000002. i am trying to solved it but it fails
hi. you need to clear that error from service mode first.
press aditional function
press 2
press 8
when #sssw appear on the screen search with arrows in the touch panel until CLEAR appear on the screen
press ok once
and search with arrows until ENGINE appear on the screen
press ok once
ERRCLR appears on screen . press ok one more time
turn off the machine from main switch for a few seconds
turn on again and make copy test .
if problem persist replace the fixing heater.
May 13, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
When I turn on my Vizio, the picture is "squished" and the bottom 1/3rd of the screen is white static. The TV is only 6 months old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 22, 2014 | Vizio Televison & Video
Good Evening Sir/Madam,I have a problem on my LCD Monitor,if i open my cpu it appears on the screen of my monitor is"Out Of Range"....what kind of problem is this sir,can you give me...
You have set too high resolution for your monitor. Follow these steps to correct the problem.
1. Switch on the computer.
2. Before you see the Windows logo, press F8 button several times. You will get the boot menu.
3. Select the option 'Enable VGA mode' with arrow keys. Press enter.
4. Computer will boot normally, but with larger icons.
5. Open Control Panel --> Appearance and Themes --> Change the screen resolution.
6. Set the screen resolution to 1024 x 768 (or something close to it).
7. Apply the settings and restart the computer.
This will solve your problem. Wish you Good luck!
Nov 12, 2010 | ViewSonic VA912 19" Flat Panel LCD Monitor
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
The screen on our Sharp Aquos flat screen tv when turned on has a blue screen that starts having black streaks appear in it. Can it be repaired?
yes sir this could th e board of your tv so go to http://www.discount-merchant.com/ and check the types of boards that we have, regards
Said
Dec 18, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sir My Nokia N73 ME is not getting switched on Only Nokia name is appearing in the screen can u help me
dear,
is it appearing and disappears after some time.
if yes then its lcd fault. u have to change it. new or used. both r available in tech shop 4 mobiles.
regards,
Dec 29, 2008 | Nokia N73 Cellular Phone
6310i has blank screen
sir if ur display is ok then just clean the pcb and display connector with pcb cleaner or molycote it will work its been tested
Aug 22, 2008 | Nokia 6310i
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
Sharp AR-5320 Black and White Copier Logo
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
