My sony bravia (32' lcd) has developed a thin vertical red line about 5 inches from the right side of the screen... it seems to ba about 1 mm thick on the bottom and fades near the top of the screen.How do I get rid of this artifact?
-   The redline on the Sony TV, mine is the same. Sony service, I contacted. Remove the power from the TV for 1 minute, they suggested.
The TV since I talked, no redline. Off and on it appears. Power removal, try, I have not. I will update if it goes away after the power removal.
-   Guest
Apr 26, 2009
-   I have a Sony xbr4 that developed a thin vertical red line, that seems to be increasing in size over the last 2 days. Also just a couple of weeks out of 1 year warranty. When the tv is off, you can still see the line behind the glass. I am very sad.
NH-   Guest
Jan 20, 2009
-   The problem we have is not one but several thin red lines that just appeared today. Depending on what is showing, the lines change to green.
-   allfinished
Sep 13, 2008
-   All of a sudden tonight thin vertical red line down left side of screen about 8 inches from side.
-   Guest
Dec 04, 2007
-   my sony bravia have the same problem.
when start the tv looks fine for a while , and when warm up a vertical red line appear gradualy. some time fade on the top-   Guest
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards CircuitCity
Was this helpful?
Yes
No
Popular Solutions for Sony BRAVIA KDL-40S2000 40 in.
Hi, I have a Sony Bravia 46", it just happen today when I turn the TV on, there is a fine green...
(More)
Hi, I have a Sony Bravia 46", it just happen today when I turn the TV on, there is a fine green vertical line displayed near the middle of the screen. Can you advice what may have caused the problem, and possible solution?.
How do I fix sony bravia lcd tv. TV remote light flashing green. volume wont change channels wont...
(More)
How do I fix sony bravia lcd tv. TV remote light flashing green. volume wont change channels wont change on tv or via remote. hard to turn off on tv. wont turn off with remote.
i have a lcd tv when i switch it on one side of the screen is dark one side is clear after a while...
(More)
i have a lcd tv when i switch it on one side of the screen is dark one side is clear after a while it comes clear br
kdl40wl140 picture blinks on then stays off ,color bars just then picture faden in then back out...
(More)
kdl40wl140 picture blinks on then stays off ,color bars just then picture faden in then back out again.Some days it comes on then it just like the first day i got it
