Question about Haier HLP21E Top Load Washer
Brand new out of box, no electric cant find the fuseable link. don't know if the computer control is messed up or what. thanks lynne
  • Haier Master
  • 1,525 Answers
Hello well if it's brand new get the engineer out straight away don't touch anythink it will void your warranty if you do good luck
shaun
Posted on Aug 02, 2009
How do i program my new time Warner remote control cable re
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Nov 01, 2015 | Televison & Video
1995 Oldsmobile Cutlas Ciera
I guess the short answer is I don't know.
There really isn't a guide to tell you want the fuse equivalent is for a fuseable link. The car companies use the link because it will carry more amps than a regular fuse, and take longer to blow.
You are supposed to replace-repair the wire by using a fuseable link repair kit where you splice another fuse link into the circuit.
The headlights use a 20amp circuit breaker, and the other circuits are probably 10amp or so. You might get away with using a 30amp fuse but I can't say for sure. In reality the circuits are fused after the link so its not likely your computer would be damaged, but a short in that main circuit could blow several fuses at one time.
Aug 21, 2012 | Cars & Trucks
Cant get power anywhere on 1992 chevy 2500 pickup no lights nothing has brand new battery
Check your ground cable. It should go to the motor and two the chassi (bolted to a fender).
Look for fuseable links. They always seem to move. They are about a 10 gauge sized wire with a plastic collor on it near the end. There can be some coming off the battery cable at the starter, on a junction block mounted on the firewall (If I remember right your 92 will have a cover on the passenger side firewall and I think they are under that) or near the battery.
Don't just look at the links (the fuse is actually the wire. It melts away when there is a circuit problem), tug a bit on them. They will corrode on the inside of the plastic collor and the wire may not be melted away but the connection inside can be bad.
If a link is bad, DO NOT REPLACE WITH A REGULAR FUSE. I seen people do that and a fuse, like found in the interior fuse panel, creates a resistance. You don't want to turn a 10 gauge wire into a small wire like found in a fuse. Napa auto parts has fuseable link wire. A but splicer and a ring splice would also be needed.
If the links are good then you need to check the bulk head connector on the drivers side firewall. The battery power will go through that inside the vehicle.
Sep 30, 2011 | Cars & Trucks
Tries to start,won't run
Have you checked that the fuel pump is "humming" in the fuel tank when the ignition is in the "on" position? If it's not,the easiest thing to check, which 99.9% of people don't know about Trackers is a fuseable link located behind your rear tail light (driver's side). If you remove the tail light find the PINK wire (on CDN ones anyway, you can check the top of the fuel tank to see what color it is) where it connects to the fuseable link, this is your power wire, if the link looks melted you won't get power to the fuel pump. Check this before you buy any parts, if it's melted cut the wire on both sides of the link and add a new piece of wire (3-4") and connect the two ends and seal it with silicone or at least electrical tape, it should start now.
Sep 08, 2011 | 1994 Geo Tracker
Diagnostic scanner not recieving any communication from computer on 2002 montero. no elec to fuel pump etc. Could thie be a fusable -link or relay, if so which one? I have no book or schematic. Any help...
Yes it can be go to the engine junction box and look at fuseable link 6 this control the fuel pump relay as for no communication test pin 16 of DLC for 12vlts also your battery has a fuseable attatched check those because it is a fuseable link the way you test it is pull slightly if it stretches like a rubberband then its open and will need a replacementcansmo_145.gifcansmo_146.gif
Aug 29, 2011 | 2002 Mitsubishi Montero
No back up liights - 2002 Envoy bulbs replaced.... box fuse is good ??? Is there an inline fusable link somewhere????\r\nMargie ridgeriverrealty@gmail.com Thanks!
i don' think that there is a fuseable link,the problem could be the reversing lights switch or a problem somewhere in the wiring......cheers
Jun 27, 2011 | 2002 GMC Envoy
No electrical at all
Fusable Link Should be Checked with Test Light. The Problem is Obviously a Power feed Problem Check the Power at the Solinoid there has to be an OPEN Power Supply Wire somewhere there ,Also check BODY GROUNDS,
Feb 22, 2009 | 1981 Ford F 150
Fuse box
THERE IS A FUSEABLE LINK BETWEEN FUSE BLOCK & BATTERY, IT IS BLOWN. THE FUSE IS AN INTERGRAL PART OF THE WIRE HARNESS.. YOU NEED TO REPLACE THE LINK. SIMPLY CUT OUT OLD LINK, SPLICE IN THE NEW ONE.
Nov 03, 2008 | 2003 GMC Envoy
Haier HLP21E Top Load Washer Logo
44 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
