Question about Dryers
Whirpool LER4634JQ1 runs but no heat checked the vent it is fine ...no lint build up in either the dryer or the vent
  • 5,911 Answers
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuit can be accessed by simply removing the back panel of the dryer. The heating circuits will be located on the right hand side. The Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set (part number AP3094244). Failure to do so may result in premature failure of any parts you replace. The heating element part number is AP3094254. All these parts can be found at appliancepartspros.com.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Aug 02, 2009
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
Ler4634jq1
The longest distance possible will help with the lint build up don't kink your hose to a 90 degree angle as it will block air flow. Curves are fine and you sould allow for a little leway as you may need to move the dryer at some point .
Jul 17, 2013 | Whirlpool LER4634J Electric Dryer
Dryer works fine except it does not seem to heat properly. Wondering how the element is installed and where I could find replacement heating element.
I would need a model number to look up your heating element.
I can tell you that chances are if the dryer heats, but just takes to long to get things dry the heating element is probably ok.
Poor air flow is what causes dryer to take longer then normal to dry.
You will want to check your vent for restrictions such as kinks or lint build up. Don't forget to check the outside hood as it has a flapper or even a screen that can catch lint.
If your vent is ok then you need to take the dryer apart and check for lint build up around the blower housing and fan.
Aug 02, 2011 | Dryers
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer won't heat
Check the exhaust vents for any build up of lint inside
A moister sensor detects this and will keep the heat off until it is cleaned thoroughly
May 29, 2010 | Samsung DV218AEW Electric Dryer
My Whirlpool Dryer LER4634JQ1 (no heat)
most likely a thermostat that has failed, I'm having same problem and am just now learning how to test. research " testing dryer thermostats and fuses online"
Oct 08, 2009 | Whirlpool LER4634J Electric Dryer
DRYER SHUTS OFF ON HIGH SETTING- FINE ON LOW HEAT
lets start simple on this,first check your dryer vent for obstructions(mainly lint build up,)also check the weather flap (where your unit vents to the outside)this should swing open when the unit is in operation.either one of these can cause excessive heat build up in the unit.(this will cause the thermal limit switch to shut the unit down)thus keeping you from setting your clothes on fire.hope this helps,thanx for using fix-ya
Nov 25, 2008 | Dryers
My 29" whirpool dryer is not putting out any heat. I have checked the lint vent outside and cleaned it( It was very dirty)and I checked my fuse box and it is still not putting out heat. Mod...
The following link describes how to diagnose and repair a dryer no heat problem:
If your dryer vent was clogged, chances are you have lint build up INSIDE the dryer as well. Read through the paragraph that discusses the proper ventilation for a dryer. I would recommend you open the dryer cabinet and clean it out thoroughly. Lint build around the heating element can smolder and is a fire hazard.
The most common failed component in a dryer that overheats is the thermal cut-out (TCO). If the TCO is bad, it is strongly recommended that you replace the Hi-Limit Thermostat with it. These components are usually sold as a set. Failure to replace both components can result in premature failure.
Make sure you follow the advice given and check and verify all possibilities to rule out multiple component problems. In addition, make sure you read the bottom section of the link, first and make sure your voltage at the wall receptacle is correct.
I hope this information helps you. Let me know if you require further assistance.
Nov 15, 2008 | Dryers
Hotpoint dryer
Completely disassemble your vent from the dryer to where it exits the building. Clean out all lint. Disconnect the dryer from the electrical service and check for lint build up inside the machine. This lint build up usually makes the motor shut down on it thermal overload. Check the motor also to see if the air vents on it are blocked with lint. If no lint is present, the motor or the start relay need to be replaced.
Oct 24, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
308 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
