Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Oven door handle
How do you remove the door handle to replace it
  • 2976 Answers
SOURCE: ordered a replacement handle for oven door, trying to figure out
Open to the first hold area, where you set the door to broil. Lift off the hinge bars.
Posted on Mar 08, 2009
0 characters
1 Points
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door To remove most oven doors:
  1. Open door to the BROIL POSITION, where you feel hinge catch slightly.
  2. Place your hands on both sides of the door near the handle.
  3. Lift the door up and away from hinges.
  4. If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
  1. Place your hands on both sides of the door near the handle.
  2. Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions. Download a copy of your Owner's Manual and/or Installation Instructions
Aug 11, 2016 | GE Profile 30" Self-Cleaning Freestanding...
How do i remove the oven door handle
On most ranges you have to remove the inner door panel to replace the door handle. Careful when you do because the door may spring up on you due to the removal of the inner panel the door is lighter. On many units the door can be locked in the down position to stop this from happening. If not, remove the door from the unit and carefully disassemble, then re-install it.
Jan 17, 2015 | Kitchen Ranges
How to replace oven door handle
You have to remove the door from the oven, and take it apart. This may not be a job for a do-it-yourselfer, unless you are mechanically adept.
Sep 11, 2014 | Kenmore Kitchen Ranges
Handle on oven door is coming loose; how do we access the screw in order to tighten it?
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the sure to replace any insulation properly.
Mar 06, 2010 | Kitchen Ranges
Handle is broken on JVM1640AB004 Can I replace
The handle on a microwave oven door can easily be replaced. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
If you have not purchased a replacement handle yet, the part number is WB15X10024. It can be purchased at any of the foloowing websites:
All these sites offer great service and competitive prices, so shop and compare.
You can view an exploded view diagram of your microwave at any of the first three websites I listed for reference. Just type in your model number for your search criteria. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 30, 2009 | Kitchen Ranges
How to replace a oven handle on a FRIG. electric oven , FES367
it's easy
open the door to first catch. About 10 to 12 inches it will stop and stay there. next pull the oven door off it's hinges. just give it a **** and it will slide right off it's hinges. after the oven door is off remove the screws from the outside panel. save them in a safe place cause you will need them to hold the door together. now that it's cover is removed you will see the 2 screws that hold the handle on. Thats it reverse it to put it back together. it's easy you can do it your self... sawdust46
Aug 03, 2009 | Frigidaire FES367 Electric Kitchen Range
Oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Mar 13, 2009 | Maytag MER5555Q Electric Kitchen Range
Ordered a replacement handle for oven door, trying to figure out
Jan 21, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Oven door handle
Lady, you are going to have to take the door apart to get at the handle screws. The whole door will lift off the hinges, place it down on a flat surface and go from there. You can find your manual with instructions at
If that link doesn't work, go to, click on the Maytag section, follow the links, enter your model number and you will find your manual. Make sure to take your time, these can sometimes be a pain. Catriver.
Jan 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
240 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
