Heating & Cooling Logo
M
Michael Beylo Posted on Jun 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Carrier thermostat screen shuts down for 10 seconds and then comes back.
T Wolgamuth
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 280 Answers
  • Posted on Jun 22, 2018
T Wolgamuth
Master
Level 3:
Dedicated:
Answers
280
Questions
0
Helped
151249
Points
2183
If it's like mine (and lots of others, I sold Carrier), the little door covering the controls at the bottom gets "tired" and doesn't close all the way. Walking by it can cause it to turn on sometimes. That little door switch could be causing your issue too. Does the equipment run without trouble? Obviously there are other problems that may be causing it, ut that's the simplest one to check. tape it tight and see
5 Related Answers
A
Anonymous
  • Posted on Jul 24, 2007
SOURCE: Projection TV keeps shutting down
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
Anonymous
  • 9 Answers
  • Posted on Dec 15, 2007
SOURCE: Carrier XHD183D Through-the-Wall Heater/AC runs constantly
YOU COULD EITHER HAVE A THERMOSTAT PROBLEM OR FAN CONTROL PROBLEM.TURN THE POWER OFF AT THE FURNACE AND TAKE THE THERMOSTAT OFF THE WALL.MAKE SURE YOU MARK THE WIRES SO YOU KNOW HOW TO HOOK IT BACK UP AGAIN.RESTORE POWER TO THE FURNACE.TOUCH THE WIRES THAT WERE HOOKED TO THE R & G TERMINALS ON THE T-STAT TOGETHER AND HOLD THEM THERE.OBSERVE THE OPERATION. WHEN YOU TAKE THEM APART DOES THE BLOWER STOP?TRY IT A FEW TIMES. IF IT CONTINUES TO START AND STOP YOU GOT A BAD T-STAT.JEFF
Anonymous
  • 927 Answers
  • Posted on Sep 26, 2008
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
pierre1811
Perry Putnam
  • 144 Answers
  • Posted on Jan 19, 2009
SOURCE: Carrier Weathermaker SX (model 58SX100)
There is a small tube that comes off the inducer for cracks or water. If there are cracks then the pressure switch that it is attached to may not be closing all of the time. Also sometimes you can get water in that tubing which will also cause the pressure switch to not close. If thats the case shorten the tube so there is no low droop in it where water can collect. Another thing that I would do is disconnect the tube at the indicer, take a straightened out paper clip or stiff wire and poke it in the nipple on the inducer to make sure it is clear too. Let me know if any of these work. There may be other things we can do.
Anonymous
  • Posted on Jan 10, 2010
SOURCE: Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
2answers
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
I AM WORKING ON A CARRIER 90% FURNACE. IT WILL NOT FIRE UP. IT SHOWS A 34 CODE. THE IGNITOR DOES NOT ENERGIZE FROM THE BOARD. NO POWER COMING FROM THE BOARD. I HERE A CLICK AS IF IT IS TRYING BUT NO...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
3helpful
2answers
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
2helpful
2answers
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
5helpful
Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
2answers
Carrier electric furnace
what are you talking about. Turn the thermostat back up. It shouldn't matter what you set the thermostat too because it is just a switch that tells the temperature.
Power issue
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
