SOURCE: 1995 Ford Probe sputtering, dying. Won't start now.
to make sure the fuel pump is operating get in a quite place get in vehicle and turn ignition switch on position you should hear alittle buzz for about 2 seconds try this several times if no buzz is heard then the fuel pump is not running. check fuel pump relay in power box by switching relay with one of same type thare should be one of same type in the box if not then purchase one and try it. If the pump is ok then you know you have a firing problem. check to see if you have spark by taking one of the spark plugs out then hook spark plug wire to it lay it on engine and look for spark while someone turns the ignition switch as if trying to start car
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
SOURCE: 6yr old Craftsman Lawn Tractor - Koehler 18 HP Auto. Sputter&Dies
Try running it again and when it starts to die remove the gas cap and see if it starts to run better. It's possible that the gas tank isn't venting correctly. If that doesn't work post back and we'll try to come up with some other solutions.
SOURCE: starts but won't stay running
I had the same problem with my Husqvarna. I thought it was the fuel system, but I was told to check my gas cap for proper venilation. When the mower starts to sputter, unscrew the gas cap to let the air flow. If it isn't venting right it will actually pull the gas out of the carb.
SOURCE: mower dies after running for a few minutes
It sounds like the carburetor is running out of fuel.First make sure the tank is full then loosen or remove the gas cap when it starts sputtering to see if that corrects the problem. Then with engine off remove the fuel line that goes from the tank to the fuel pump,hold it low and see if any fuel flows out of it,if not lightly blow air backwards to the tank,(with fuel cap off),then see if the line is plugged. Next remove the fuel line that goes to carburetor from the fuel pump,crank the engine and see if any fuel flows,if so the carburetor should be cleaned by removing it and disassembling it.
