Question about Canon PowerShot A720 IS Digital Camera
LCD Screen remains black
I can take the picture and it shows up right after for a second and then disappears. I can also see the pic i took if I switch to the review mode - its only when I take the pic - completely black screen. I have not spilled anything on it - worked fine yesterday, went to use it today and nothing - just black.
I've only had this one for just over a year. I had another Canon powershot before this but lasted much longer before running into this same problem. I didnt mind replacing that camera b/c it lasted longer - but this one is just over a year. Can this camera be saved this time? This is ridiculous....
  • 300 Answers
Hi!
Have you tried pushing the DISP button while taking pictures? It's on the right from the LCD.
Tom
Posted on Aug 02, 2009
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Black screen
At this point I believe there are failed caps in your monitor.
http://www.badcaps.net/forum/showthread.php?p=73310
This is very common in all LCD monitors. Did the tech just push the power switch off and on?
From my experience at fixing broken monitors of all brands, I think it is the power supply problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
You can get second help from repair shop also.
Apr 20, 2010 | Gateway FPD2275W LCD Monitor
Screen going to black no picture, shows a few second and disappears
First thing to look for are bad caps in the power supply section, see example of failed monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 16, 2010 | HP Pavilion F1703 17" LCD Monitor
Black screen no picture got sound
if its an LCD check by holding a flashlight to the screen looking for the pic. if u see the pic the backlight/inverter has failed.
Dec 06, 2008 | Televison & Video
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Canon powershot a540 black/web screen display
jvsnype and ygjeff21, have you checked to see if the pistures also come up as blank or distorted (a sure sign of a CCD failure)? If the pictures are OK, then it might be that you accidentally hit the DISP button, or the camera has a loose LCD ribbon cable connector. The reason I would suspect either is that ygjeff mentioned that the LCD would spring to life when he played with the buttons on the back of the camera.
If and only if the camera still takes good pics, and the DISP button has been checked, then would next recommend reseating the LCD ribbon cable into its connector (ALSO ONLY IF THE CAMERA IS NO LONGER UNDER WARRANTY). The following link may be of some help. Wouldn't recommend going any farther than the first three pictures. You just want to jiggle or reseat the ribbon cable where the LCD connects to the circuit board, nothing else:
http://photography-on-the.net/forum/showthread.php?t=251630
Feb 06, 2008 | Canon PowerShot A450 Digital Camera
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
223 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
