SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
SOURCE: my consew 226R-1
Hello lilliang ,
You can check out the procedure in ur manual itself in detail!!
SOURCE: feed dog not pulling fabric
First, remove the needle plate and using a small screwdriver, clean the packed lint from in between the teeth.This will allow the teeth to go up.
sewman7
SOURCE: The dog feed stuck in the downward position.
Have you turned the machine off and then back on?
The switch may be broken and you will need to find a sewing machine repair shop that repairs all brands of sewing equipment.
If you decide to purchase another machine try a different brand. This one seems to have on a lot of issues.
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
