I was listening to my vr-407 and all the sudden click and now in protection mode it only stays on for 3-5 seconds and then it goes off how do I fix this issue
CHECK FOR CLEARED COOLING VENTS & FOR PROPERLY WORKING COOLING FANS. THIS WILL CAUSE SHUTDOWN OF THE UNIT. IF ITS ALL CLEAR, YOU PROBABLY HAVE A POWER SUPPLY ISSUE.
Connect the amplifier input to the VR-407 using the receiver's REC OUT jacks for the MD/TAPE input on the back panel. This is a fixed line-level output for recording, and will work fine for driving the additional amp.
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
You will need to go to audio set up and make sure it is set up to play with a center chanel if you have one as well as the surrounds. You can also only have side a speakers selected when trying to use surround. If you have b selected it will play in stereo only
