Question about Cell Phones
Connecting to a jabra hands free
The phone finds the jabra sp500 device but doesn't connect
Re: connecting to a jabra hands free
My Jabra BT2010, was conecting to my phone, now , all of a sudden it is not...even though when ever i switch it on the password prompt is use putting in either 0000 or 1234.
Posted on May 15, 2009
  • 316 Answers
Once you have found it it should then ask for a pin code which is either 1234 or 0000
once this is accepted then they should be paired completely
Posted on Nov 26, 2007
0 characters
3 Points
Jabra Cruiser2 Type HFS002. Need help with connecting Jabra to cell phone via bluetooth.
If you have the instruction manual on the jabra, it should tell you how to put the device in pairing mode. Once pairing is turned on you find the device name through the bluetooth settings on your phone. Click pair and they should connect.
Aug 16, 2016 | Cell Phones
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
I recently got the Motorola Droid X and paired & connected by jabra vbt2050 with it and it worked. Today though, when placing a call with the Jabra, I could hardly hear the call. Now I have not power...
To see if the problem is with your bluetooth connection, try sending and recieving files with your bluetooth. If it is successful, then try borrowing 1 jabra device and test it with your phone. The bluetooth connection and the jabra device are the problems I can see since you said it worked once.
Hope this helps! -jayps
Mar 09, 2011 | Cell Phones
I have my first cell phone pair with my Jabra BT2035 headset, how do I pair my second cell phone with this headset?
While you can't actively be connected to 2 phones at one time, you can pair with more than one phone. Just turn off the headset, then hold the call/end button on the headset until the status light stays solid. Initiate search on the 2nd cell or PC/Mac and if prompted enter the 0000 pair key.
Now you can connect to the Jabra from one or the other phone/computer. I used this method for to connect to my blackberry for work and n97 personal phones.
Jan 06, 2011 | Cell Phones
I have a jabra bluetooth how o i connect to my phone
You need to put the bluetooth device in discover mode, then on the cell phone, you configure the blue tooth settings to "find" the bluetooth headset. Check out this document on how to pair a Jabra (may not be your model, but bet it is the same process). Good Luck!!
Oct 17, 2010 | Cell Phones
I just found an old (about a year and a half old) Jabra bluetooth freehands device. However, every time I try to pair it with my phone, it can't find the device. the model of the device is GNM-0TE3. my...
I just hooked it up to my iphone, What you need to do is set your phone to bluetooth searching then hold the top power button down on the jabra til the light is flashing, Then hold the jabra next to the phone and hold down the center button on the jabra for a couple of minutes and your phone'll pick it up, hope this helps, if it dont email me at and we'll figure something else out.
Aug 16, 2010 | Nokia Cell Phones
I have a Jabra hands free device and my new Samsung Impression is not finding it when I hit search for bluetooth device ... my old samsung phone had no such problem. How do I find the Jabra with my new...
clear all the names of th e devices stored in the3 cell and then click on new device and search it , it will show the new device or the name of your device , pair it and click connect -----------------------------------enjoy
May 21, 2010 | Samsung SGH-A877 Impression Cell Phone
Cannot get my 3gs handset to find and connect to my jabra hands free visor set
its because its an apple i phone, they wont pair to anything else other than apple i phone. (they dont tell you this when buying)
hope this helps
Feb 09, 2010 | Apple iPhone Smartphone
Connection to jabra sp5050
yes if you go into settings find connectivity and choose bluetooth it should say switch on or off and that will be permenat
Jul 02, 2008 | Motorola Mobility V365 Cellular Phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Dec 14, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
370 people viewed this question
Top Cell Phones Experts
Are you a Cell Phone Expert? Answer questions, earn points and help others
