Question about Casio Exilim EXZ75 Digital Camera
When trying to charge my battery... the light flashes red. And the battery doesn't work when put in the camera. Is that a battery problem or charger problem?
  • 300 Answers
Battery problem. Well known problem with the NP-20 battery. It can be repaired by connecting it to ~4-4.5V 1-1.5A for about 5-10 seconds and then charged normally with the charger.
Of course a new battery will be better.
Tom
Posted on Aug 02, 2009
Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Mar 04, 2013 | Canon VIXIA HF M41 Camcorder
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
Battery will not charge, red light flashing on charging port.
new battery is required as it is too discharged to work after a year's time.
Jul 20, 2010 | Casio EXILIM Digital Camera
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
Does not charge,red flashing light on charger
Take a nine volt battery and put + to + and - to - for ten seconds and try to charge again if it does not work then you need a new battery.
May 25, 2009 | Casio Exilim EXZ75 Digital Camera
My casio exilim s880 is playing up
Here's what I found and it actually worked after about 7 times. Others said they had to do it about 20 times. Good luck!
ylu1 writes:
what i did was...
hope this helps.
Dec 09, 2008 | Casio Exilim EX-S880 Digital Camera
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Casio Exilim battery won't charge
What model of camera? You will probably need to purchase different battery.
Mar 18, 2008 | Casio Exilim EX-Z40 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
579 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
