Question about Canon EOS 400D / Rebel XTi Digital Camera
Camera will not turn on. was working and went
Camera will not turn on. was working and went to turn it on and nothing shows. battery is fully charged. camera was bought in feb this year.
    New Friend:
  • 28 Answers
HI I AM SAGHA CAMERA REPAIRER FROM MUMBAI, I THINK I HAVE TO SAY THAT YOUR CAMERA IS DEAD RIGHT NOW,A VERY LITTLE YOURSELF CAN BE DONE.YOU HAVE TO TAKE IT TO SERVICE STATION.BECAUSE OF SOME MALFUNCTION THE POWER SECTION OF YOUR CAMERA WENT OFF.BUT DON'T WORRY IT CAN BE RECTIFIED.
Posted on Aug 02, 2009
Sony digital camera problems
Either your camera is shorting the battery or the battery is no longer holding a charge. The easiest solution is to try a different battery. If that doesn't work the problem is with your camera.
Diane
NYC Photo Safari
Apr 29, 2014 | Cameras
Black screen no image showing
black screen blur image showing cannot see subject to be photographed when camera power on,if press to take photo nothing shows, just black screen. it was fine one minute then nothing the next. battery is fully charged, memory card ok.
May 24, 2010 | Olympus FE-230 Digital Camera
New ex-z33 simply won't turn on. press on/off button, nothing. press and hold on/off button, nothing. place battery in another exilim camera and it turns right on and shows battery is fully charged. camera...
If its less than a year old take it back to the vendor and ask them you demonstrate it for you. If they can't demonstrate it to your satifaction request a refund or replacement. I Suggest you take the receipt or proof of payment as well.
May 01, 2010 | Casio Exilim Zoom EXZ33 Digital Camera
Canon PowerShot S2 IS camera showing code E18
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jan 20, 2010 | Canon PowerShot S2 IS Digital Camera
New camera with fully charged battery won't turn on
It may be something more serious, or your new batteries may be too low for the camera to work properly, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 06, 2009 | Samsung SL202 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
My camera doesnt work.
i suggest that there is likely a motherboard fault or a board fuse has blown. the fuse needs to be replaced by a qualified technician, this will prevent any further damage to motherboard.
Jun 07, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Kodak Z700 not firing up
I have the same problem. Removing the memory card and then starting up seemed to fix it; the camera would then start up ok even with the card in.
Mar 08, 2008 | Kodak EasyShare Z700 Digital Camera
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Canon S2 IS won't turn on with rechargeable batteries??
I would let them charge til you get an indication that they are done. TV remotes require very little power to operate, while digital cameras need a lot, so that's why the batteries would work in the remotes though not fully charged.
Jun 16, 2007 | Canon PowerShot S2 IS Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
