Question about Baumatic F60 Stainless Steel Kitchen Hood
F90 st.steel hood fan problem
Lights still work, but fan works intermittently. Even if you hold the button down, workd on and off, not al the time. Can you suggest anything please
  • kerrym Dec 09, 2007
    Thank you I will try that. Appreciate your help.Kerry
  • 833 Answers
Kerry, does it make any difference if you hold that button or not? If so, the switch set could be bad. Any odd noise from the motor? The motor might be bad. Power off. Then, remove the filter and try to turn the motor by hand. If it turns hard, it's the motor. Easy, then replace the switch. Check the electrical connections to the unit. There should be a box somewhere inside the housing. It is possible that wires have come loose. Again, do this part with the power off.
Posted on Dec 09, 2007
We have replaced our control panel PN 99003139, THREE times. Each time same thing happens. The lights and buttons gradually and intermittently go out. The dish washer will still run, so long as the st
Whirlpool parts come with a one year warranty WP owns Jenn Air take it back I have replaced this panel then had to go back and change again in 3 days it failed yes could be a bad batch of panels the panel is powered by the control is the control taking out the panel can't say it is a computer maybe sending to high a voltage to panel no way to test that
Jan 30, 2015 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Hood lights not working
Faulty switch for the lights? Measure the voltage in the lamp sockets - if you don;t know how, find someone with electrical experience to check it out.
Nov 21, 2013 | KitchenAid KHTU165RSS Stainless Steel...
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
Our Kitchenaid Range Hood model KWCU405SSS has a code "C" in the display. What does that mean?
I just did this and it works.
1.) Make sure to turn off both the fan and the lights. If you skip this step the next step won't work.
2.) Press and hold the + button for 4 seconds until the "C" disappears.
Repeat in another 100hrs of use.
Mar 19, 2011 | KitchenAid Architect® II KWCU405SSS...
We turned the fan and light on our TURBOAIR S88 90 ST/ST 90CM CURVED STAINLESS STEEL CHIMNEY HOOD there was a flash from behind the buttons and now doesn't work is there a fuse that needs to be changed...
Sounds like the lamp has failed and maybe damaged the power switch. This, if installed correctly, will be fed from either a fused plug or a fused spur.
If it has been fitted incorrectly, no idea.
Jan 23, 2011 | Microwave Ovens
Hi. Last Friday we had a new Kenmore stainless steel range hood installed along with a new range. Yesterday the range hood fan and lights would not work. The fan does not come on at any speed. The lights...
Some installers plug the fan/light into an outlet in the cupboard above. Check to see if that has power. Some of the outlets are behind a panel in the cabinet above and you have to remove the screws. I have seen the plugs laying in the cabinet just like they had never been plugged in. Yours obviously was plugged in but maybe fell out. If the fan/light is hard wired than you should make sure the power is turned off at the breaker box and then check the wiring inside the box to make sure it is wire nutted together and is holding. I would also check that the breaker for the fan/light is still putting out power. These last two might be a little tricky if you have never tried them. The breakers sometimes go bad but look like they are set. If the whole hood fan is not getting power it is probably time for an electrician or the people who installed to come back.
Aug 25, 2010 | Kenmore 52153 Stainless Steel Kitchen Hood
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Baumatic F60 Stainless Steel Kitchen Hood Logo
332 people viewed this question
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Vitaliy Gins
Vitaliy Gins
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
