Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
The saw works but sounds weak i cleaned the brushes but still the same thanks for any help
  • rnc1217 Aug 02, 2009
    thanks for the quick answer i thought of that when i spin the saw by hand the bearings sound o.k. when i press the switch it sounds like its got a slight delay and then it sounds like its not at full power and not loud like its should .thanks for the help
  • 90 Answers
The bearings probably need changing
Posted on Aug 02, 2009
Extremely weak motor model 108526-01 remington
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Feb 12, 2014 | Remington Garden
Table saw keeps tripping breaker
May have a brush in the motor that's hanging up or worn may try
replacing the brushes
Feb 07, 2014 | Saws
I replaced the brushes in my skilsaw and although it works fine, it has some sparks when i use, should i lubricate?
Depending on how old the saw is some spark when fresh brushes are installed is common. The brushes have to seat into the armature. If the sparking continues after a while the armature may be getting weak. There is nothing to lubricate that will cure a sparking issue with a power tool. Just keep using it, but keep an eye on the sparks, if they get worse, the armautre should be replaced.
Jan 10, 2011 | Bosch 7 - 1/4" Skilsaw Circular Saw
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Jun 28, 2010 | Remington 16" Electric Chain Saw
Bosch 4000 table saw will not start. I changed the switch and still won't start, not even a sound. The saw is relatively new, and the outlet works. What should I try next?
A real Weakness of this saw is sawdust and debri entering the cooling ports of the motor causing intermittent contact of brushes which damages the motor speed control board ($40.00). Don't ever operate this saw with out a vacuum saw dust extraction system. Also when you replace the Speed control board also replace the Brushes ($6.00). It helps extend the operational life of the motor components to blow out the contaminants regularly with compressed air through the motor cooling ports (turn off saw first).
You can bypass the speed control board (if you want to disable this wonderful engineering feature by attaching black and white power wires directly to the black and white wires to motor.
Feb 22, 2010 | Bosch 4000 - 07 Electric Table Saws
Sir i m azim from fiji dewalt dw 871 xe model chop saw sparks too much at brush.also sounds different.so what the problem .sir technicians say the coil.we tested its ok.we changed armarture but still the...
Hi and welcome to FixYa. I am Kelly
With power off grab both sides of the blade and try to rocking (NOT SPINNING) the blade in opposide directions on each side of the balde. Then while rocking the blade, see if the armature teeters inside the motor.
It it does have excessive movement then the rear motor bearing is probably worn excessively.
I have to ask if this is a 110V cut off saw and your trying to use it on 220V because it will produce the exact symtoms you described.
I also note that you did not mention if you had changed the brushes. Worn brushes or weak brush springs can also cause the symptom you describe.
Hopefully this gives you something to work with.
Thanks for using FixYa!
Kelly
Feb 21, 2010 | Dewalt Chop Saw D28700
I have a Dewalt dw 705 miter saw.when you pull the trigger the saw starts for a second and then shuts off. I have replaced the brushes and it worked for a few minutes and quits. the brushes do not seem to...
the armature needs to be cleaned or it is possibly bad (open bars) They make a special cleaning stick called a commutator stone that you might be able to purchase at a local repair shop. If you are not comfortable trying this I would recommend taking the saw with you, To clean properly you have to remove a cover and have the saw running, I would also check for proper movement in the brush tube allowing the brush to freely contact the armature. Let me know if you need more assistance and I will try and help.
Nov 10, 2009 | Dewalt Saws
Bosch 4000 table saw won't work
OK sounds like you are handy. You have electric to the brush tubes? (first unplug saw to test) If yes then I would remove the brushes to see if they were making contact with the commutator. Does the blade spin freely? If not you might have a bearing problem. I would again use air after removing the brushes and then reinsert making sure they seat on the armature. If still nothing then if you are comfortable I would pull the motor housing. But before pulling go to Bosch Tools website and downloading a breakdown of your saw. Let me know if I can help
Jan 15, 2009 | Bosch 4000 - 07 Electric Table Saws
Makita 10" Dual Slide Compound Miter Saw with Light LS1013F Logo
54 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
