Question about Maytag M6P09S2ACOM Air Conditioner
Besides the filter directly in the back of the machine is there an inner filter or something else I can do to insure proper cool air flow ? I did dissemble the entire back and carefully washed the coil. It runs good, but I feel it is not cooling enough. Does it require freon. or recharging ? Thanks Gary
    Novelist:
  • 116 Answers
Hi, there are no inner filter to be clean, you did good job by cleaning coils at back, but you should try to clean evaporator or cooling coils, is possible you need to service it, remove it, strip it down cover all electrical parts, and give him a bath, power hose, then leave it to drain for about 2hr before putting it together, that should be done by trained mechanics, also you should check size of room, and AC b.t.u, it could be possible, your AC is not right b.t.u, you should check and make sure you have the right amount of b.t.u AC for size of room.
Posted on Aug 02, 2009
I have a 1999 chevy silvarado my heater\AC vents do not work properly anymore. Everything comes out on the floor.
I would suggest to check the selector switch. If there is a loose connection there you will not be able to select the direction where the air should flow.
Jul 26, 2008 | Chevrolet Silverado Cars & Trucks
Tip
Why does my A/C blow little to no air, that's not cold, and how do I fix it?
Air Conditioner freeze ups cause an A/C to blow little to no air through the vents, and the air is usually warm.
There are three basic reasons for air conditioner freeze ups:
  1. Insufficient air flow
  2. Low Refrigerant charge
  3. Outdoor temperature
1) The two most common causes of insufficient air flow are dirty filters and under sized ducts. A dirty filter limits air flow which in turn allows the cooling coil’s temperature to drop below freezing. Replacing the filter, monthly, usually alleviates this problem. Under sized ducts will also cause the system to freeze because it also limits the amount of air flowing over the cooling coil. This results in lowering the coil temperature and allowing the humidity in the air to collect on the coil and freeze.
2) Low Refrigerant Charge. The refrigerant system teeters on a delicate balance. If the system is not charged correctly, the system will not function properly. This malfunction may result in the poor cooling output and/or freezing up. Only a qualified, certified service technician can properly test and charge a refrigerant system. Check your small high pressure line (should be hot) and low pressure line (should be cold, but not frozen).
3) Outdoor temperature. If temperatures are too low, the system will not operate properly, and freeze up may occur. The outdoor unit does not function well in temperatures below 60 degrees F. A special “ambient temperature” control must be installed to allow the unit to run properly in cool temperatures, or you may open your windows and save energy. If the A/C is set lower than 70 degrees F, special adapters are required to be installed.
on Jul 10, 2010 | Heating & Cooling
Ilet the filter on my unit get clogged and it quit cooling. after i cleaned the filter it still doesn't cool.
"If your dirty filter caused your problem,' it was because it restricted the air flow across the cooling coil. Often if the filter is clogged then the air will divert around the filter itself - and clog the cooling coil too, in which case you will need to clean the cooling coil.
The cooling coil is looped in a coil (hence the name) and is comparable to a car radiator. You will need to clean the fins (that are entwined around the coil) so that air - can flow unrestricted, over the coil.
This can usually be accomplished with a brush of some sort. Often you can use your fingers to peel the moist mat of hair and dirt off the front of the coil.
The problem (usually) is getting to the coil, because once you get to it - it generally is not that hard to clean. Your goal is make sure air flows thru the fins and over the coil - unrestricted of dirt, hair, or whatever.
Remember - many things can cause an AC unit to 'not cool' besides the filter being dirty - which is why I prefaced my answer with 'if your dirty filter caused your problem'
Good Luck!
May 02, 2010 | Dometic Rooftop RV Air Conditioner
No air is blowing out the vent and it takes forvere to dry the clothes
without air flow your dryer will not work. it has to be able to remove the water from the clothes by blowing it out of the dryer.
what you need to do is go thru the back of the dryer and find the long duct that the lint filter slides down into. the are 4 screws that hold it to the inner panel, remove this duct or just pull it out away from the inner panel and check to see what is inside it blocking the air flow.
that will cause your trouble and it will dry properly after that.
Mar 13, 2010 | Kenmore 62602 Electric Dryer
Fan blad to condensor
Air flows from the inside through the air filter and into the AC unit. The evaporator coil "cools" the air and the blower pushes the air back into the area to be cooled.
Hope this helps and good luck! :-)
Feb 25, 2010 | Coleman Mach 15 Air Conditioner
Yesterday i changed the fuel,pollen and air filters this morning the car started ok but idles rough
Was the Fuel filter installed properly (fuel flowing through the filter in the proper direction). Fuel filter components on the inside only allow the fuel to flow through properly in one direction. On the fuel filter itself there should be an arrow pointing in the direction the fuel should flow, or it could have "in" and "out" stamped on the ends. You may have gotten a little dirt in the fuel line as well that now may be clogging a line or injector causing the car to run a little sketchy.
Jan 17, 2010 | 2001 Ford Focus
Running high head pressure in heating cycle runs fine in a/c cycle
Check your indoor air filter. When the unit is in heat pump mode the indoor unit is cooling the air, ie. removing the heat from the unit. If the air flow is restricted then the unit will run high head pressure. If the filter is clean then maybe something else is restricting the air flow of the indoor unit. The other possiblity is that the unit is over charged. When in cooling the overcharge will not create the problems that it will in heating mode. The only proper way to charge a heatpump is to remove ALL the refrigerant and then wiegh in the proper amount of refrigerant into the system.
Nov 19, 2009 | Heating & Cooling
My airconditioner lines keep freezing up
Your filter is plugged, or the refrigerant is low, or it is getting too cold outside overnight (less than 60degf)
Because it also limits the amount of air flowing over the cooling coil. This results in lowering the coil temperature and allowing the humidity in the air to collect on the coil and freeze.
2)Refrigerant charge. The refrigerant system teeters on a delicate balance. If the system is not charged correctly, the system will not function properly. This malfunction may result in the poor cooling output and/or freezing up. Only a qualified, certified service technician can properly test and charge a refrigerant system.
3) Outdoor temperature. If night time temperatures are too low, the system will not operate properly, and freeze up may occur. The outdoor unit does not function well in temperatures below 60 degrees F. A special “ambient temperature” control must be installed to allow the unit to run properly in cool temperatures, or you may open your windows and save energy.
Jun 05, 2009 | Heating & Cooling
Instead of cooling the room, the back of the AC forms ice
Change the filter. It doesn't have the proper air flow across the coil. Hope this helps. Good luck
Apr 27, 2009 | Danby DPAC8020 Air Conditioner
Maytag M6P09S2ACOM Air Conditioner Logo
211 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
