Question about Samsung DLP HL-P5663W 56" TV
My tv screen got wet and now there are black
My tv screen got wet and now there are black spots inside the screen. How much wojuld that cost to get fixed?
  • 585 Answers
Try a hair dryer first back and forth on hot (don't melt it), DLP screens cost about $200-$400 to buy I work for a service center and have replaced them before. alot of screws around the cabinet, if you take it apart to clean it try using a damp rag (with water) or monitor cleaning kit.
Posted on Aug 02, 2009
Hi, I have a Toshiba tv model# 55SV670U and would like to know what part I need if I could hear the tv but no picture with a blue screen and large black spot. Is it the Tcon or LCD board?
-I will recommend to buy new one instead repair.
-Repair will end up spend more and still not working properly.
-The projection bulb will cost about 190 to 250 dollars.
Now at Wal-Mart flat screen is very cheap.
But if you decide to fix any way. You have to test all parts inside the TV to find out what component is bad before replace.
Good luck
Mai
Jan 12, 2018 | Toshiba Televison & Video
Growing Black Spots on Insignia LCD Flat Screen
Black dots/spots on an LCD panel display indicates either a dead pixel or a stuck pixel. Alternately, if you press lightly on the black spots and they go bigger/darker, then in some instances, it could be that the frame holding the display has been slightly warped when too strong a pressure was applied when it was being cleaned. Should this be the case then corrective measure would be to disassemble and flatten whatever area was dented. Some have reported success with the use of a suction cup. Perhaps this, this or this might be interest you.
If the unit is still under warranty, please try discussing your concern with your dealer. Though a few small spots are an acceptable norm. Alternately and if the warranty has lapsed, there are companies online that offer LCD replacement kits or will replace/fix your LCD and it would cost you less than the cost of a new screen or TV.
Other than the above, am afraid that your options are rather limited.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Insignia IS 20" TV040919 TV
47in LG led hgtv screen hit by airsoft gun; can it br fixed & how much?
Screens can be replaced but cost much more than any other component inside the tv. Adding on the labor cost to the parts list may be more than a new tv would be. Send whoever shot the tv the bill....lol
Jan 02, 2014 | Televison & Video
I have several large water spots on the lower right corner of the tv from overspray with windex. Can this be fixed?
Not a good idea to clean tv with windex. Try wet towel dipped in mild soap solution. Make sure all water has been removed and towel is only wet. When tv off, try removing the spots. Turn tv on only after tv dry.
Dec 22, 2013 | Apex Digital LD4088 LCD TV
Black spot on my element tv screen
Sounds like some of the led's have packed up. There is nothing you do about it. You cant fix individual Led's and a new screen will cost the same a new TV.
Sep 10, 2012 | Element ELC-HS321 32 in. LCD TV
Black spots plasma tv
If they are inside the screen nothing can be done and replacing the screen unit which is called a panel is out of reach as cost of the part well exceeds the price of replacing the set by quite a large amount.
May 24, 2012 | Insignia Televison & Video
My SAMSUNG DLP HLT5675SX TV seems to develop little black spots all over the screen and after a while these black spots become bright white spots. In fact if a non-used Input is selected and the screen is...
It is the chip that controls the millions of mirrors inside the tv. If they are black, they are stuck closed. If they are white, they are stuck open. I JUST had the same the same thing happen with mine. I bought it 3yr and 2 months ago and I had an extended warranty on it for 3 years. Well, needless to say, it was out of warranty and I was pissed. The store I bought it from suggested I call Samsung. Which, I did. They asked for the model number and told me that my model (hlt5675sx) was one of the ones that is covered becasue they had a problem with the chip. Within 2 weeks, my tv was fixed by a repairman who came to my house. It works perfectly, now and it didn't cost me a penny. Good luck.
Jan 11, 2011 | Samsung DLP HL-P5663W 56" TV
Hello, I have a 40" Samsung LCD flatscreen. My television has a 2.5" diameter black spot on the far left side about 4" from the bottom of the screen, Also we have a dark transparent band across the bottom...
Sorry Sir but your LCD TV got wet... it can be splash with too much water, an animal urinate on the panel, etc....
this kind of black spot is caused when the LCD Panel Terminals got wet, this terminals are located at the lower side of the LCD Panel.
Sep 15, 2010 | Televison & Video
Samsung hl-t4675s white spots on screen started now screen is almost black lost pixel what is cause
My Samsung LCD has white spots on the screen. The tiny spots seem to be increasing in numbers. I am outside my warranty. Is this going to cost a lot. It is a 43in screen.
Jul 16, 2009 | Samsung DLP HL-P5663W 56" TV
Red spots
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to work. If that doesn;t work you can replace the cord and if that doesn't work then the screen is out and would cost WAY too much to fix, you could buy you a new name brand TV.
Sep 23, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Samsung DLP HL-P5663W 56" TV Logo
1,423 people viewed this question
Jerry Greenberg
Jerry Greenberg
