Question about Cobra 19 DX IV CB Radio
Having problems hearing people trying to transmit to me. I can transmit just fine to them and they can hear me, but when they try to transmit me I ant hear them. Have tryed tuning and everying. Whats my problem?
Communicomm
  • 90 Answers
SOURCE: not real sure
Make sure that the mike gain & RF gain controls are turned clockwise & the squelch is counter-clockwise.
Posted on Jul 20, 2008
  • 3 Answers
SOURCE: Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Posted on Dec 24, 2008
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Posted on Jan 07, 2009
  • 3 Answers
SOURCE: Cb radio does not transmite
You might be having a dead key problem. Do you run a power mic? if so check the battery in it if you dont run a power mic then your have RF gain problems. Take it to a local cb/truck stop and get them to look at it.
You didnt open it up and mess with it did you?
Posted on Jan 26, 2009
audio20
  • 22 Answers
SOURCE: swr meter not moving.
If the radio is working don't worry about the meter unless you absolutely want it. These little meters are not very accurate or reliable. Get an external SWR meter to check the antenna.
Posted on Apr 23, 2009
My voice does not transmit through the earpiece
Sounds like you have a problem with your microphone.
Please contact us.
Mark
Motorola Support
CONTACT US
Jun 04, 2014 | Motorola Mobility H710 Bluetooth Headset
Binatone Action 1000 Two-way radios. We can't transmit to others. Only our selves.
These radios are probably working on a different call guard tone than the other users you are trying to reach. If you have a manual, look up instructions on how to program a different tone. Hope this helps!
Aug 19, 2013 | Radio Communications
Im having problems with my midland 77-095 im reciving lound and clear but my output is terrible people cant hear me but i can hear them>???? thanks
it is possible you are hearing peoplein skipland. skip is an atmospheric phenomenon that causes radio waves to travel hundreds even thousands of miles. there a lot of cb operators that run high power amplifiers which would make their signal go even further. this would mean you would hear them well, but your radio doesn't have enough power to reach that person. right now we are in a solar cycle which has been causing skip daily. if you know that the peson you are trying to talk to is local and within. a few.miles then there may be an issue wit either your radio or antenna. the antenna must be tunedto the radio or you signal will not radiate off the antenna completely. over time it can destroy the radios transmit circuit. so if you have never.tuned the antenna you may be causing the radio not to work well and you may have hurt the transmit transistor.
Jun 27, 2011 | Radio Communications
I can't hear people
Make sure you don't try to transmit without a proper CB antenna, it will damage & blow out the power transistors! If you have another CB close by, try listening without the antenna attached If you even faintly hear whats transmitted by the other CB, your antenna cable is probably shorted out... AGAIN don't try to transmit with no antenna or a shorted cable it will damage the unit!
Oct 22, 2010 | Cobra 29 LTD CB Radio
We are unable to hear caller but they can hear us just fine.
Hi Jess, apparently it is because the cordless phone is transmitting on the same frequency as WIFI network (wireless broadband). I am having the same problem as you and thats what I have found out. Looks like we need to buy a DECT (Digital Enhanced Cordless Technology) phone. Problem solved, so they say. Paul
Apr 30, 2010 | Uniden Cordless Phone
Cant hear anything
ya im having the same problem with mine, and im trying to play cod6. but i think its supposed to do that. but then again, why would they give u a earpeice if u cant hear anything. well, u can try pressing the volume up on the head set, and also go to accessory settings on your ps3 and turn it up. but im not sure if thats your problem, i havent tryed that yet. but hope it helps.
May 26, 2009 | Mad Catz Radio Communications
Bad transmission
Troubleshooting ideas:
1) Try the radio without the remote speaker mic (RSM) attached. Do you still have the same issue?
2) Check the RSM's mic area for dirt/debris or something covering the hole. It is usually in the lower corner of the grill area of the mic.
3) Try someone else's RSM on your radio and see if the problem is still there.
4) Check your battery. An old or defective battery will cause transmit issues. Try a known-good battery from another radio to see.
5) If all of the above are addressed and you still have an issue, you may be experiencing low transmit power, and your radio would need to be serviced.
Mar 22, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Low transmitting range on Cobra MRF55
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Tom
Dec 30, 2008 | Cobra MR- F55 Base CB Radio
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Motorola 815 with bluetooth headset loses transmit
Try using a Jabra bluetooth.... Go to newegg.com and get the Jabra for twenty-four dollars.... I was having the same problem and this bluetooth saved the day......
Jul 15, 2007 | Motorola Mobility E815
Cobra 19 DX IV CB Radio Logo
106 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
