Question about Canon PowerShot SD1000 Digital Camera
Canon 10D works fine after impact but overexposes now.
Camera was on tripod approx. 2 ft above ground w 70-200 f2.8 L. Fell forward onto lens front, lens ok for most part. Camera works fine except overexposes shots now. exp. comp. fixes it. I have an electronics degree and I wonder if there is an internal adjustment that just got knocked out of wack.
    New Friend:
  • 28 Answers
HI I AM SAGHA A CAMERA REPAIRER FROM MUMBAI,YOU SAID YOUR CAMERA WAS FALLEN ON THE FACE WITH LENS THEN STARTS OVR EXPOSING PICTURES THEN FIRST CHECK YOUR LENS'S APERTURE IS WORKING FINE OR NOT.ATTACH ANOTHER LENS TO YOUR CAMERA & THEN CHECK THE EXPOSURE THEN IT WILL BE CLEAR WHETHER YOUR CAMERA IS DEFECTIVE OR LENS IS DAMAGED INTERNALLY.REPLY ME ABOUT IT.THANK YOU & ALL THE BEST
Posted on Aug 02, 2009
Repair - How can I fix a broken lens/AF/MF?
If you have another lens, try that on the camera to determine if the damage is the lens or the camera. If the lens is damaged, just buy a new one, I would not trust the elements to focus true on a lens that has had an impact severe enough to cause this problem. As this is the standard lens that ships with most Canon Packages, you can likely find a cheap one online.
Sep 10, 2016 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
How to mount 67mm thread lens to t4i body only canon
One side of the reverse adapter has a 67mm thread, the other side has a lens mount. Mount it to the camera body as if it were a lens. Bear in mind that it's intended to screw onto the front of a lens and then mounted onto a camera to put the lens onto the camera in a "backward" position.
Dec 16, 2012 | Fotodiox 67mm Filter Thread Macro Reverse...
Sigma 70-300 error 99 on canon 20d &10d
If the macro switch is held on the lens by 2 screws it is to old and will on work on your camera but if yous is a super type it may need a rechip
Nov 13, 2009 | Sigma Zoom Telephoto 70-300mm f/4-5.6 DL...
Lens error
You will most likely need to send the camera in for service. There really is no way to repair this problem on your own.
Since you are not out of your 1 year manufacturer's warranty, you will not yet qualify for the upgrade program, however Canon does offer deep discounts in the Canon Loyalty program for situations like yours once you are beyond the one year manufacturer's warranty.
It may be true that it would cost more to repair than to replace, and that's why the Loyalty program is great because you will at least save a bundle on getting another camera.
Hope this helps.
May 27, 2008 | Canon PowerShot A540 Digital Camera
Canon Powershot Pro1
I also have the same problem and I took it to the canon service center. They told me that I have to replace the whole lens kit the problem was with the shutter not closing properly thus overexposing the pictures
Feb 26, 2008 | Canon PowerShot Pro1 Digital Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Lens Error
Only Nikon can tell you that. Looks like the autofocus lens mechanism broke inside.
Nov 19, 2007 | Nikon Coolpix 8800 Digital Camera
Nikon Coolpix 8800VR Digital Camera
I have heard of this problem and it was sometimes solved by the following...
1. Remove battery and memory card
2. Place a paperback book on a solid surface
3. Bump the camera firmly on the paperback book
4. Reinstall battery and test
Worth a shot if it can save you from sending it in for service.
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Digital dsc F707 problem
I used Super Glue and my camer ia stil working.  However you need to be very careful taht no glue gets onto the lens itself as it cannot come off and will give your pictures a blurred effect
Sep 11, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
77 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
