Question about Honeywell CT3600 7 Day Electronic Programmable Thermostat Heater
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
I have a Florida Geo heat pump 2 stage with no aux.heat. It is controlled by a Zone Perfect Two-Zone Unit hooked up to two Totaline P274-0300-C thermostats. Everything works great this way.
I was talked into buying a Honeywell VisionPRO TH8320U1008 to replace the Totaline on zone-1. They said the Honeywell can be wired for any system. Anyway, I can't take it back and I can't get it to work properly.
The Totaline is wired as follows BLK-0/W2/B RED-R BRN-C BLU-Y/Y2 YL-Y1 GRN-G WHT-W/W1. A total of 7 wires hooked up.
The Honeywell only calls for 6 wires to be hooked up in the 2H/2C Heat Pump mode with [no auxiliary heat] I hooked the wires up as follows BLU-Y2 RED-R/RC Note, R+RC are jumpered. BLK-0/B YL-Y GRN-G BRN-C. I stored the WHT wire. Wired this way the heat pump would work, but would not control the reversing valve when when calling for heat.
The Florida Geo heat pump has the the reversing valve energized in the cooling mode.
Any help with this problem will be greatly appreciated.
Thanks,
Bill
    Problem Solver:
  • 4 Answers
On the honey well tstat you have to go into the installer set up and set the swithover valve for energized in cooling
Posted on Jan 19, 2012
The thermostat will to any temperature but will not shut off
Posted on Jan 28, 2009
The functions seem to be frozen. what do I do?
Try removing power to the thermostat including the batteries for 20 seconds and see if that solves the problem.
Sep 24, 2014 | Honeywell Th8320u1008 Visionpro Digital...
Wiring honeywell th8320u1008
Be sure you are looking at the letters set up for heat pump. Orange should be "O". Remove jumper between w2 and e. Then be sure you have the settings correct in the tstat for a heat pump with back up heat. Good Luck!!
Mar 28, 2017 | Heating & Cooling
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Mar 04, 2010 | Heating & Cooling
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Honeywell Thermostat
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Dec 23, 2008 | Honeywell Electronic Programmable...
Thermostat Wiring: W2? E? Where to connect?
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
Dec 15, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,385 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
