Question about Celestron Optics
I can't see thru it. It looks like there is a
I can't see thru it. It looks like there is a black disc over the opening.
How do I get the disc off?
  • sunyjim May 11, 2010
    I'm sure the black disk is a lens cap. What kind of celestron telescope is it? refractor, reflector or shmidt cassgrain?
  • 3,186 Answers
Are you talking about the dust cap on the end of the telescope? It either screws off, or is just friction fit and comes off.
Need more details-- what brand and type of telescope do you own?
Posted on Aug 04, 2009
After self clean I lost all power to my gas oven and the door has remained locked. Help please ?
Based on your description I would check for an open Thermal Overload Device looks like a flat disc located behind the back panel of oven kill the power and with a meter check for continuity thru the fuse
Feb 16, 2015 | Kitchen Ranges
Freezer not defrosting
try to rotate manually defrost timer possible stock up or the thermo disc defective replace it or the dfrost heater busted need technician for replacing this parts conduct observation after.
Mar 04, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
I have a MS1000 Black and Decker Cyclone round sander..looking for replacement sanding disc
Hello, W/D here.
Most sanding disc types are available at the larger box hardware stores. They are (sometimes) generic or exact replacements.
I use the "Gator" brand on my B7D sander, and the discs work just fine.
Best regards, --W/D--
Feb 23, 2011 | Black & Decker Black And Decker Cyclone 4...
Gas tank will not open
There is a wire broken in between the door and door jam. Slice the black boot the holds all the wires "carefully". Mine was the large orange wire. Spiced back with solder and heatshrink tubing.
Apr 22, 2010 | 2006 Volkswagen Jetta
Disc changer won't open, won't play DVDs. RCA RTD
Check the belt inside underneed the tray if this is still in place.
if not put belt back on
Feb 15, 2010 | Bose Lifestyle 12 System
Xbox 360 the draw wont open, only will open a little bit but not enough to put a game in ..
Sometimes cleaning the belts inside the disc drive is enough to get the tray to open and close again.
First follow the tutorial for your drive to get the tray open here:
http://www.llamma.com/xbox360/repair/manual_eject_xbox_360_dvd.htm
Take a look at this picture.. this is the drive disassembled(you do not need to disassemble the system at all.. stay with me a sec). See that white circle all the way on the left and in the middle of the pic. Not the white gears, the white circle that is right nex to the gears. It's got a little black belt that is attached to another black piece. That is the belt you need to clean.
Now.. how to do this without opening the 360?
First of all make sure the 360 is completely off and the power is disconnected.
Hopefully you've already gotten the disc drive open using the manual eject instructions above. With the tray completely ejected look into the opening for the tray. You can see that white piece and the black belt are right there easily accessible with the disc tray open.
Now you will need to do this to both sides of the belt!
Dip the Q-tip in rubbing alcohol.. Dab it a bit so it's not dripping off, you just want it nice and damp.
Gently place the Q-tip on one side of the black belt.
While continuing to gently press on the belt with the Q-tip you should close the disc drive about an inch or two, then open it back up again.
Repeat this process with the other side of the belt.
If it's very dirty you can do this a few times.
Let it sit for a few minutes and you should be good to go! If not you will need to replace the disc drive motor... however this will usually work about 75% of the time. Let me know if you have any questions.
Then take a Q-Tip and dip it into rubbing alchohol.
Nov 20, 2009 | Microsoft Video Game Consoles & Games
I have a Gateway M675 laptop. It was stolen on Mothers Day 2009. I received my laptop back into my hands 2 days ago, long story as so how I got it back. I tird to powerup my laptop, but it would open with...
you will have to check online for your BIOS setup it is trying to boot from something that is not there have to set BIOS from UEFI to normal.
Or
Install windows using thumb drive and win32disk to install windows to thumb drive then boot from thumb drive by pressing F12 or F11 for boot order
Feb 28, 2017 | Gateway M675 Notebook
HP Designjet 5500 - Black not printing
there is a blockage and you need to replace your tube assembly. and maybe your APS.
Jan 27, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
Nikon FG 35mm
If its black when you look thru the viewfinder its likely because the mirror is stuck in the up position. It will often do that if the batteries are exhausted. Try replacing the batteries.
The mirror might release back down if you turn the shutter speed dial to M90. This is a manual release of 1/90 second for when you need the shot but don't have any power.
When you look in the lens opening and adjust the aperture dial, you are seeing the aperture open and close. Not the shutter. You need to open the back of the camera (without film) and take a photo to see the shutter curtains open and close.
You should have a read thru the manual to become familiar with the camera and its operation:
http://www.cameramanuals.org/nikon_pdf/nikon_fg.pdf
Jan 03, 2009 | Nikon FG 35mm SLR Camera
Optics Logo
97 people viewed this question
Top Celestron Optics Experts
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
