My dell lcd monitor keeps going off after two seconds. I turn it off then on again and it goes off yet again.
  • 2,841 Answers
Hook another monitor to the computer and see if it goes off. If it does not then the monitor is defective and must be replaced. If the spare monitor goes off, then the problem is with the computer video output. Check the video card.
Posted on Aug 02, 2009
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Dell E173FP 17in flat LCD goes blank after about 10 seconds
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Jul 11, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
Monitor comes on for a split second , and then off
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Dell monitor 1703FPs
you backlights are going off.y ou need to replace the power supply in this monitor very comon problem
Dec 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
MY DELL SE198WFP GOES TO POWER SAVE MODE AFTER 2 SECONDS
I had this problem as well as a lot of other people. The solution is to go to the power options in the control panel and turn power saver off. This should keep the monitor from going into power saving mode.
Dec 29, 2008 | Dell SE198WFP LCD Monitor
LCD monitor turns off after 2 seconds from boot
Try to see the video card and fell if it is hot, if the fan is running when turn on. There is a part of your computer that is hot, that when reach to that temperature it trun blank or off.
Thanks
Nov 19, 2008 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell Flat Screen Monitor
hello can someone help me?? the problem is when i turn the monitor on i just can see shine white i can do anything my monitor is del E197FPf lcd thanks a lot
Jun 25, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
