kawasaki 2010 Jet Ski Ultra 260X Logo
G
Geneva Posted on Jun 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove a starter on Kawasaki 25 horsepower
Steve P
Level 3:
  • kawasaki Master 3,912 Answers
  • Posted on Nov 12, 2021
Steve P
kawasaki Master
Level 3:
Answers
3912
Questions
5
Helped
1303220
Points
15904
This is a simple operation. DIsconnect the battery before attempting this....its a really simple operation... if it seems complicated to you..?? PLEASE take it to a professional mechanic!!
2011 Kawasaki Ultra Jet Ski. Torque specs please.
They are here
http://www.theskiclinic.com/kawasaki-tech.html
Or do you mean engine torque as related to horsepower?
Maximum Torque 152 N·m (15.5 kgf·m, 112.1 ft·lb) @7 250 r/min (rpm)
https://www.google.com/search?q=2011+Kawasaki+Ultra+Jet+Ski.+Torque+specs
Apr 29, 2023 • Jet Boating
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
1helpful
New engine Kawasaki 25 hp mower engine has fuel starter engages won't start. I pour gas in carb it starts and run for few seconds what up.
Carb is not feeding gas to motor. Rebuild or replacement is mandated.
If there is a switch on the gas line to the carb it has to be turned on.
How do i remove a 1982 kawasaki kz 1000 starter motor
Follow the specific instructions in the Factory Service Manual. Step 1 - Remove the heavy wire from the starter solenoid. Either end will suffice. Step 2 - Remove the chrome cover over the starter. Step 3 - remove the screws that hold the starter motor in place. Step 4 - Lift the starter motor out of the engine. NOTE: removing the carbs may make this step simpler. The "business" end of the starter should come out of the splined starter clutch gear. If you have trouble removing the starter from the clutch gear, you may need to remove the left side stator cover to gain access to the starter clutch and chain. The exploded parts diagram is available HERE Kawasaki Motorcycle Parts 1982 KZ1000 J2 STARTER MOTOR STARTER CLUTCH...
Removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
Jun 15, 2009 • Boating
2helpful
Horsepower rating
I can tell you what mine is. I have a K&N Air filter and Cobra Power pro 2 into 1 pipes on it. Also a Power Commander USB III. I had it dyno tuned (each cylinder) and the results are Maximum HP 75.01 and 78.24 ft-lbs torque. I'm not sure what it is stock. Probably in the 62 to 68 range. The dyno tuning made a HUGE difference in how smooth the power curve is.
Top kawasaki Boating Experts
 vpsoccer
vpsoccer
ADMIN Andrew
ADMIN Andrew
jws1013
Are you a kawasaki Boating Expert? Answer questions, earn points and help others
