SOURCE: need code tv brand name celera
I Finally found the code for the Celera Tv, try 053 or 192, But how do you get the tv back on when the remote is out.
SOURCE: remote control code I have a seiki tv and I bought
go to www. remotecodelist. com or memorex.com
and download
God bless you
SOURCE: my seiki tv detects wifi but won't connect. even after i enter the password. how do i fix this?
One reason I can think of for your problem is this: your TV detects several other protected WiFi networks (probably from your neighbors) in addition to your own, and it is likely that you entered the password for your network when trying to connect to another network. To check if this is the case and if you don't know your network's name (actually this is called the network's SSID), do the following: turn off your modem/router, then check what WiFi networks are detected by your TV. Write down the names of those networks. Turn your modem/router back on and see what networks are now detected by your TV. The new one on the list is your WiFI network's SSID. Make sure that you connect your TV to that new network.
Testimonial: "Thank you. Did not think of that. I had to switch my router from WEP to WAP and change my password to a shorter one."
You need to enter the password assuming it is compatible.
Testimonial: "how can i find if wifi is compatable"
