Question about Sterling 402315-96 Biscuit Windham Two-Piece Elongated Toilet 402315
Where could I find the flapper for Sterling 1.6GPF toilet?
    President:
  • 1,273 Answers
Here's the easiest way: Close the water valve that supplies water to the toilet. Lift the lid off of the tank. If you look in from the top, you'll see a long white tube in the middle of the tank running from the top to the bottom. It is called the overflow tube. At the base of the tube is the flapper, and it anchors to the base of the tube, and is actuated by the handle on the front of the tank pulling the chain connected to the flapper. Flush the tiolet, and you'll see what I'm talking about. To replace the flapper, you'll need a replacement. Remove your flapper and get a pretty good look at it. You can buy a replacement at any hardware store. A 'universal' replacement should fit, but take the old one with you to be sure. When you look at the new flappers, you'll notice a rubber ring attached to the flapper, and you may not have one on yout toilet. No worrys here, the ring can be cut out if yours is of the type that just clips onto two lugs at the base of the overflow tube. Install your flapper, hook up the chain and turn the water back on.
The chain should have just a little slack in it.
Best regards, --W/D-- please feel free to rate this solution....Thanx!
Posted on Aug 02, 2009
Problem with water leakage at flapper valve on eljer toilet
recheck flapper may have replaced it with wrong one
Nov 26, 2012 | Home
Flapper leaks
this is a case that dictates you replace the flapper.
Mar 06, 2011 | Eljer 141-0220-00 Toilet Tank White
I need a new flapper, where can I buy one?
any local home improvement store or this website:
http://www.sterlingplumbing.com/why-sterling/toilets
Mar 06, 2011 | Sterling 402315-96 Biscuit Windham...
My daughter did the experiment of putting food coloring in the tank, then, we waited an hour and the color was in the bowl. Is it true that this would signify a leak in the toilet?
That is a very strong indication that you need to replace the flapper. As there are a lot of different makers and types I would recommend you try to match it up or go with a universal repair flapper. When you are installing the new flapper check the sealing surface to make sure there are no rough spots that could cause a lesk. If there are you can remove all water from the tank and use medium grade sandpaper to smooth it up. I hope this helps you.Thanks.
Feb 17, 2011 | Sterling Home
Replaced flapper water still getting through
They sell a replacement lip for the pipe that the flapper sets on. It cost about 12.00 dollars and is really simple to install. Just make sure you buy the one with the small tank above the flapper to give extra pressure.
Aug 25, 2010 | Sterling Home
Im looking for a flapper for a sterling 1.6 GPF toilet . The universal flapper doesnt do it
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Nov 04, 2009 | Sterling 402315-96 Biscuit Windham...
Small streams of H2O down interior sides of commode bowl. Have replaced flapper and color tested for leakage,Nada, replaced ballcock fill assembly with Fluidmaster unit and still getting very small...
this is still the flapper.each toilet has a flapper designed to fit each toilet.your may not have the right flapper for the toilet you have.not all flappers weights are the same.youmay need to add some weight to the flapper or replace it with one that is designed for that model toilet.good luck with your project
Sep 29, 2009 | Home
I replaced my Sterling 1.6GPF with universal flapper and it still did not fix the water leak into the bowl.
make sure chains not too tight otherwise it holds the flapper open just enough to let water thru
Aug 07, 2009 | Home
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Sterling 402315-96 Biscuit Windham Two-Piece Elongated Toilet 402315 Logo
2,333 people viewed this question
Top Sterling Home Experts
Tim Whalen
deton8 von Splosion
Are you a Sterling Home Expert? Answer questions, earn points and help others
