Question about Craftsman Garden
Lawn tractor won't move when put into gear
Craftsman OHV30 13.5 hp rear engine, manual transmission
the problem is that I can get it in all the gears and can feel it engage but it won't operate..all gears will barely move the tractor if not sitting on the seat (no weight)
The mower will turn on and just idle, can move the gear stick from N to R to the other gears and it will not go into gear is it possible that it popped out of gear and wont go back for some reason. so i am thinking of dropping the gear box down and seeing inside. thanks joe coots Ky
Posted on Jun 04, 2010
    Genius:
  • 1,114 Answers
First, check the tension of the drive belt. There should be an idler pulley which is spring loaded that creates the tension. When you push the clutch in, it will release the tension. Also, check to see if the rear wheel hubs have set screws which lock them onto the axle Make sure they are tight.
Posted on Aug 02, 2009
Craftsman lawn tractor won't shift into gear
have you removed a rear tire recently? If so, you may have pushed the square key that locks the rim to the axle out
May 20, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 917273482 will not shift into gear, and I can't push it because it won't disengage
If there is too much play in the drive belt due to belt stretch or linkage wear, the belt will be too loose to drive the tranny but still cause the tranny input shaft to rotate preventing it from being put into gear.
Do the gears grind when trying to put into gear? With engine off you should still be able to push the machine if you put it in neutral. Unless, of course it is a hydrostatic transmission, in which case there should be a lever to push/pull which will put the hydrostat in neutral. This is all assuming that it is a hydro and while running the machine won't move when putting the drive lever into forward or reverse.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I put the rear end of my craftsman lawn tractor on a cinderblock to take the rear wheel off and fix it. It was on the block for a couple of day. Now my tractor won't go forward or backward. the belt...
Did you forget to reinsert the key or did it slide out while putting the wheel on. A quick way to check is if you remove the center cap and have someone put it in gear and try to go while you are watching the axle. If the axle is turning and the wheel is not then the key is missing.
Sep 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
687 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
