My washer fills with water while not running
You will need to replace the hot/cold water inlet solenoid. IF the water is flowing into the washer, when the washer is off, the gasket is damaged in the solenoid OR the solenoid has failed. This should fix your problem.
Appliance Parts house should have the part, turn water off and unplug from electricity - remove hoses (catch water with pan), should have about three screws holding it to the body of the machine. remove from machine mount, remove wires, one at at time and remount to new part, install new solenoid to body of washer, reassemble case, replace hoses, plug in, and test.
Should fix problem. I would suggest replacing hose washers, while you have the hoses off from the back of the machine. May leak from there next, if not replaced.
Hope this helps...
Hi Kenneth Kasee, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Yes. What about the part?
