Question about Brother MFC-9420CN All-In-One Laser Printer
When I print in color, it looks 3D. Does anyone have a suggestion? I did the yearly cleaning and even changed the yellow toner, which seemed to be the worst color out of place. Thanks, Cidny
  • 3 Answers
You need to align the head by going to the printer software.
Posted on Aug 02, 2009
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
My printer is Fuji xerox 1250, Recently i have a problem for the color issue, we tried color Calibration, We changed drum, we even reset to manufacturer default setting (by press 0+ green button and...
It seems your yellow color is not function correctly. Need to check yellow color feed and its linkage to deliver ink to your paper. Looks like it almost clog up that cause very light color in your paper. Again please check completely your color feeds.
Regards,
Dec 15, 2010 | Fuji Office Equipment & Supplies
I havean HP 2600n, anything red prints in a faded yellow. I've seen other posting regarding this put all answers suggest something wrong with the printer. However, when I had a supplies status page...
change the cartridges. Theres nothing else that can alter the color like that without rewriting the drivers. B4 you do, take each one out, shake gently from side to side to even out any toner, and try again.If they print better, your toner is low.
May 26, 2010 | HP Color LaserJet 2600n Printer
The colors of my oki c5150 do not line up, they all print but the blue will start higher then the others making it look like a 3d picture without the glasses. It is not a set amount higher, even on the...
Sir,
This is the problem with toner cartridge. This may be clogged. Remove the toner cartridge, through cleaning and insert it. It may be solved.
Thanks Good Luck
Aug 24, 2009 | OKI C3200n Led Printer
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Getting Yellow half way up the page
That is a common problem with commercial color printers using the larger color print cartridges. Change it using the same vendor and ask for an exchange credit.
Aug 27, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR BC320 not printing correct colors
sounds a lot like the print heads are clogged. Can you print a test page, and how does that come out?
Feb 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Color/picture prints are lighter than usual
This could be caused by a worn OPC drum, Transfer belt or poor high voltage output.
I would suggest the drum first.
Feb 08, 2008 | Epson AcuLaser C2000 Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
107 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
