Question about Kitchen Ranges
Stove burner gets red hot
Our Whirlpool range model RF360BXPN0 has an 8'' stovetop burner that occassionally will get red hot while cooking with it. We can be cooking on any setting and it is fine, then suddenly it will get red hot. the only way to control it is to turn it off. It is fine when we turn it back on. This only happens occassionally, but is getting more frequent. Is this the burner, switch, or some other part? Thank you.
  • ldel112 Aug 10, 2009
    Thank you for all the info. There's no burning, scorching or melting of the burner receptacle, so I have replaced the switch. So far, so good, but with it having been an intermittent problem I'll have to go a couple of weeks with the new part to see if it is truly fixed. Thanks!
  • 5,911 Answers
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at pcappliancerepair.com, appliancepartspro.com, searspartsdirect.com, or repairclinic.com.
If you have any questions, please let me know. I hope this helps you.
Posted on Aug 02, 2009
SOURCE:
How do i change a whirlpool model wbp88800 burner control
Unplug stove. There should be two screws under edge of the cook top. You need to open oven door to get at them. Remove screws, lift cook top up at the front and prop it up. There will be two or three screws with spring clips holding the burner to the cook top. Unplug the connections, remove screws, remove burner. Install in reverse. I did this at Christmas just in time for dinner. It takes about ten minutes.
Feb 06, 2015 | Whirlpool Kitchen Ranges
What is the advantage of gas range than gas stove?
There is much confusion about those terms, especially when used by suppliers / online webshops. A great indepth article about the issue can be found here: http://www.ebay.com/gds/What-s-the-Difference-Between-a-Stove-and-Range-/10000000177628290/g.html
Below is - imho - the most related paragraph:
'Many people use the terms oven, stove, and range interchangeably. However, buyers that plan to purchase a stove or a range should understand the purported meanings of each of these common words. First, the term stove technically refers only to the stovetop, which includes a number of burners (typically four to six) and is used for surface cooking such as boiling, frying, pan-searing, and other methods. The oven is an enclosed device that is used for baking, broiling, roasting, and other cooking methods. It employs concentrated heat within the enclosed area, which is usually delivered via heated coils in the top and the bottom of the stove. The term "range," as defined in Webster's Dictionary, actually refers to the combination of stovetop and oven into one kitchen appliance.'
Hope this helps :)
Jun 27, 2014 | Whirlpool Kitchen Ranges
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
I have replacedsurface unti terminal block with kit supplied by whirlpool part dealer. Though all other burners work on stovetop, the large burner still won't heat up. I alsp bought brand new element from...
Good morning,if you've replaced the burner and block and it still isn't heating,you definitely have a bad burner switch. On an electric stove you have two lines of 115 volts going through the switch to the burner. If one of the lines through the switch has burnt out,you may still get the burner on light. Hope that helps.
Jun 05, 2017 | Whirlpool RF302 Electric Kitchen Range
Stove won't work. Stovetop burners are fine but
if this unit is equiped with a electronice control board then you need to check the power coming from the board to the ignitor.most cases replaceing this board will solve your problem
Mar 04, 2010 | Kitchen Ranges
I have a Kenmore stove and was cooking several things on stovetop burner and accidentally put a plastic bag of tortillas on top of hot burner and the plastic melted all over the burner. I soaked the burner...
We are factory authorized Kenmore service & parts suppliers. We have all the parts you might need.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct burner element out to you asap.
We look forward tow roking with you and getting you cooking again soon.
Nov 09, 2009 | Washing Machines
Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
Oct 20, 2009 | Maytag MER5775Q Electric Kitchen Range
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE Profile stovetop w/4 burners doesnt stay hot enough to cook on anymore
I would check to see if you have 220 Volts to the stove, even if you have only one leg with 110 volts to stove it will let the burners get half hot. with out the model number i don't know about any censers. The flat tops have temp sensors on them. but not that operates for all four. I would check at wall receptacle first for 220 volts first but only if you are qualified to work with electricity REMEMBER it can injure or KILL you.
Feb 05, 2018 | Kitchen Ranges
Kitchen Ranges Logo
1,546 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
