Question about Kenmore 43142 Front Load Washer
My washer stops and f20 display on screen - Kenmore 43142 Front Load Washer
    Brigadier General:
  • 3,513 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. - Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running.
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thank You for using Fixya.com
Posted on Aug 02, 2009
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
Stopping mid cycle and showing F20
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Code problem on the machine is F20
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
also, those flood prevention hoses they sell you don't work well with front load washers
Jul 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi, What does a F20 error mean on a maytag 3000 series?
See this page: http://maytag.custhelp.com/app/answers/detail/a_id/2887/~/display-shows-f20-or-fh---front-load-washer
Your washer water valve inlet screens may be dirty / covered with debris and need cleaned. Some hoses have additional screens installed at the faucett connection depending on who did the install process. Low water pressure will also cause this code.
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Maytag Washing Machines
What does the F20 message mean??????
Well the error F20 on display means (Water Inlet Problem, no water or insufficient water supply)
You can please check the following -
Post comments for further help or information..........
Good Luck!!
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting F20.
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I'm getting a F20 code?
“F20” on display
water supply)
Nov 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Kenmore 43142 Front Load Washer Logo
79 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
