Es muy dif?cil encontrar o conseguir ese tipo de software . Incluso si lo encuentran es posible que no funcione. El fabricante env?a un c?digo de activaci?n para que el software funcione y eso solo lo env?a a los distribuidores autorizados .
The error "006" can occur for many reasons, which we explain below, starting from the most probable to least probable. It is recommended if you have questions or problems with the procedure write a comment, they are always answered and help solve other problems.
Incompatibility with the service tool and printer
It is possible that the program for resetting you are using is not compatible with your computer, in most cases this error appears as a result.
It is recommended that where got the service tool, verify that printer is compatible even with the same name as the tool can search the Internet service compatibility, you can ask in a comment to this publication.
Not followed the correct procedure to enter the service mode
Enter the mode of service is an important part to restore print pillows, if not properly enters the service tool will not work or will file errors when trying to run it. The options for selecting in the program are disabled.
Clean the connectors of the printer and cartridges
The cartridge connectors (copper contacts in the front of the cartridge) and printer connectors, located also in the front of the head must be clean in its entirety, means, they may not have stains of ink or lint that can prevent proper operation.
Check printer drivers
In some cases when you test that everything is working properly, and the problem still continues, you should uninstall and install again the printer drivers, so with the printer off until the software installer asks you to connect it.
This error may occur if there is a network maintenance or outage. Please click here to check our Network Maintenance / Operational Status page.
If you receive this error code, please try again.
If the issue persists, review your DNS settings, and update the settings to auto-obtain. [How to]
If this is already set to auto-obtain, you may try entering an alternate DNS, such as Google's DNS. [How to]
