Question about Jensen Car Audio & Video
No AM reception
I have a Jensen mobile radio (JCD3006) that gets absolutely no AM reception. FM is fine. The antenna is securely plugged in. Even if the antenna is bad, shouldn't I get at least some reception or static when tuned to a strong broadcast?
2 Suggested Answers
SOURCE: FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
Posted on Jun 15, 2009
No FM radio reception,AM reception is okay.
You are going to have to pull the radio out and make sure that the antenna wire is plugged in securely to the back of the radio, this would give you the FM channels.
Aug 23, 2011 | 1992 Ford Explorer
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod . http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Jensen VM9510 Car DVD Player
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
May 31, 2009 | Jensen CD400M CD Player
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
FM RADIO DONT WORK..MODERATE AM
hi sounds like a torn ant wire or bad ant change the ANT with all the length wire till the reciver make sure a good connection in the reciver good luck
Mar 26, 2006 | Jensen 200W AM/FM/CD Car Receiver - CD4610
Car Audio & Video Logo
77 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
