Question about Sewing Machines
Model 385.15718500..machine only goes in reverse
Model 385.15718500..(machine only goes in reverse now .)
stitching is fine but machine reverse lever didn´t work... tried moving stitch length and width slides,out of frustration...
, now lever moves but machine only goes in reverse and not forward...what can be done the machine is only 3 years old.
  • Sewing Machines Master
  • 1,388 Answers
Sounds like the reverse mechanism has jammed...either with lint or lack of use and oil/lint has frozen the mechanism.
Unplug the machine and remove the base. Clean all the lint with small brush and vacuum.
Try the reverse lever to see where the connecting rods are and identify the collar around the bottom shaft....try to move manually, use a little lubricant where the collar moves on the shaft.
In extreme cases it may take several applications over several days to rectify this, but as this is only 3 years old, should respond quickly
Posted on Aug 02, 2009
How to regulate stitch-length on Brother DB2-b756
On most machines there is a lever on the front of the machine that goes up and down that lever controls the the stitch length and reverse
Jun 12, 2016 | Brother Sewing Machines
Where is reverse button
Depends on the make & model of your machine. Would be best to consult the owner's manual. Mechanical and computerized machines also vary. Mechanical machines usually have a stitch length lever that, when pushed all the way up, will reverse stitch, or there is a button usually marked with an R or an arrow. Computerized machines usually have a button marked by a U-shaped arrow.
Of course, if you have a vintage sewing machine, it may not even have a reverse stitch. Instead, to sew in reverse, one would have to sink the needle into the fabric, raise the presser foot and swivel the fabric 180 degrees, drop the presser foot and stitch.
To find a copy of the owner's manual, search the internet for:
Manufacturer + Model + the word "Manual"
sewing machine reverse Google Search
Dec 04, 2015 | Sewing Machines
Does it have a securing stitch function?
it is called a reverse stitch and you have to push the button or slid the lever .
Oct 28, 2015 | Sewing Machines
How do relase the Reverse Lever for Singer 756 when using the flex stitch mode
This man is your best source for getting your machine back on track.
http://www.tandtrepair.com/700TS.html
Mar 04, 2015 | Singer Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
Is there a reverse stitch button on singer 457
On the right is a lever .. Bottom has numbers .. Mid says "fine" .. Move that lever up to the top for reverse
May 08, 2010 | Singer 3116 Simple
Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Oct 06, 2009 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
292 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
