Question about Coleman Pack-Away
Re-energize generator Does anyone know the way to revive a dead generator. Ex. 5000watt with 10hp B&S engine
  • 4,059 Answers
If engine runs but no power, the rectifier is probably bad.
Posted on Aug 02, 2009
What is the recommended oil capacitiy for a pulsar 6000w generator
This unit show to have a 10HP gas engine and thus should have a dip stick where you add oil. Guess 10HP gas engine 1.0-1.5 qts?? You can always drain it and measure. Than add it back...Good Luck
Jan 01, 2017 | Electrical Supplies
My storm cat 60338 portable generator runs fine but won't put out any voltage
Lee, You may have to re exite/flash/energize generator. Below are links to show how to do it.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to re energize Dead Generator
endtimesreport com
http://www.garagejournal.com/forum/showthread.php?t=108313
Re Energizing Dead Generator
Apr 23, 2016 | Electrical Supplies
I would like to know what type and how much oil do I use in my powermate generator with the Subaru 10hp engine. thanks you
Your small engines require ordinary 10W30 motor oil.
Don't turn machine on its side or upside down to drain oil, or oil will run into carburetor.
Use a plastic hose to remove old oil
Oct 22, 2010 | Coleman Powermate Premium Plus 6250W...
Can i install electric starter on 10hp briggs & stratton ?\r\n Thanks !
Easy to check if your engine was designed for additon of starter. Starter motor is mounted at rear of engine to gain access or flywheel. The block would need to have mounting holes already drilled into block and the flywheel will need to have ring gear. There should be a removable plate on fan cover (or cutout) to allow starter to enter flywheel. If your block has mounting holes but not the geared flywheel, you could try to find a dead motor with good starter parts at small engine shop. Good luck
Sep 11, 2010 | Electrical Supplies
I have a Generac 5000 Power Plus 10HP Model 09856-0 Series 401 4891. It works fine but the gas tank petcock leaks. Where can I get a replacement and for reference I'd like to get a parts manual for future...
The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
Part Mfg: GENERAC Part Number: GEN 78298 This Part has been superseded arrowdown.gif Part Number: GEN 080270 Price: $5.34
When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
You can also order the 080270 tank valve here:
http://www.jackssmallengines.com/searchdb2.cfm
If you enter the part number on the search page.
$4.60
Thanks for using FixYa.
Kelly
Jun 10, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
I need to seperate the 10hp Tecumseh engine from the Generator? Best Procedure?
Simply unbolt it...nothing sp[ecial there remove the bolts that hold the generator to the engine housing the remove the bolts the hold the gen to the frame (if any)...REMOVE GENERATOR
Feb 02, 2010 | Coleman Powermate Premium Plus 6250W...
Where is the oil drain plug for a briggs and stratton 11 hp engine?
ACCORDING TO POWERMATE, THIS GENERATOR IS EQUIPPED WITH A 10HP SUBARU ENGINE. WHAT MODEL IS YOURS? AND R U SURE IT'S A B&G ENGINE?
Dec 14, 2009 | Coleman Powermate Powermate 5000W...
Coleman Pack-Away  Logo
410 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
