Just bring it to the technician. They can help you better.
Change your Ac connects liner transformer
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
SOURCE: Sony Bravia KDL-46Z4100
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
SOURCE: I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
SOURCE: Sony Bravia KDL-46V3000
turm on the tv for at least 24 hours with rf signal it will automatically get ok.
SOURCE: vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
