Question about 2wire (1000-400108-001) Router
I cant access xbox live because my mtu is below 1364... how can i change this setting
    Problem Solver:
  • 11 Answers
It's not your MTU setting, you actually need to open some ports in your modem or router. Xbox can explain the port numbers, and www.portforward.com can help with the details.
Posted on Aug 02, 2009
2 Suggested Answers
dexterlim29
  • 70 Answers
SOURCE: how do i change my 2wire routers mtu settings cant
you need to call your internet service provider because that is the firewall of the 2wire.
Posted on Jun 17, 2010
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Connection interruption while playing xbox live
Xbox LIVE recommends using an MTU value of 1364(defaults are 1492 and 1500) on your router.
You will need to log onto your Router, go to the setup section, locate the MTU, set it to Manual, and change the Size to 1364.
If that doesn't work, you will need to clarify the following:
  1. How many machines(do you have other computers?)
  2. What router are you using
  3. Ethernet or Wireless?
Sep 28, 2009 | NetGear WGR614 Wireless Router
I recently got wireless internet from a Zonet router and i cant connect to my XBOX live account because it states that i dont have a sufficient MTU setting of 1364 which i need to connect to XBOX live
Go to your router, you can do that by simple going to a browser and then put your gateway in it. You will be asked for a password, after that you can now change the MTU setting in your router.
May 02, 2009 | Zonet ZSR3104WE 802.11G MIMO WIRELESS...
Xbox live is not working it keeps coming up with 'you need an active connection to play online or system link matches' but my connection is fi and none of my friends can play as well?
Suggestion: <b>MTU Error</b>
Things to try:
Sep 30, 2008 | Video Game Consoles & Games
Mtu failure
Things to try:
My xbox live is saying mtu failed
MTU stands for maximum transmission unit, which is, the maximum data that can be transmitted each time a network device sends out a signal.
I don't think you can change the MTU in the Xbox 360 dashboard.
You will probably have to go through a router to get around it.
the Maximum transmission unit is 1500, but for the Xbox 360 it must be set within the range 1364 – 1492.
So please access to the router setting on your PC & set it within the range 1364 – 1492 or call your ISP or router manufacturer to assist you doing so if you do not know how to access to your router settings.
I can give some steps to access router settings,
The way to access to your router settings differs from one router to another but basically it will always be through your PC most of them would be as follows:
1. Open an Internet explorer page on your PC.
2. On the address bar type 192.168.1.1 as for Netgear routers and 192.168.2.1 as for Belkin routers or 192.168.1.1 as linksys routers, if you have even any other brand you can try these three numbers I reckon one of them will work.
3. Then you click GO.
4. You'll get your router settings main page on the screen asking you for your Username & password usually by default the password will be even the same as the Username (Username: admin, Password: admin) OR it will be password (Password: password).
5. You can there look for MTU settings, it differs from one router to another you can just look for it then set it to 1365 as we said before.
Hope my info fix your problem,
Thanx for using fixya,
Cheers.
Sep 29, 2008 | Microsoft Xbox 360 Controller
Xbox live mtu
That setting should be on the Setup page. Your best bet is to add the TCP and UDP ports to the applications/gaming page. Check the XBOX faq's for those port numbers.
Jun 02, 2008 | Linksys Wireless-G Broadband Router
Changing the MTU setting
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
May 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
2wire (1000-400108-001) Router Logo
274 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
