Question about Maytag Dryers
I have a Maytag Performa PYE2300AYW and I'm experiencing a very strange problem. One day my door switch just stopped working. The dryer continued to run even when the door was open. Since it still dried I just ignored it for several months. One day it started overheating after running for just a few minutes. I switched it to air fluff so the heating element wouldn't come on and it ran through the entire cycle. The strange thing I noticed is that the door switch was working again. After opening the dryer up, cleaning it out (it wasn't very dirty) and putting it back together, I noticed the door switch didn't work anymore. I switched the heat back on and it heated and dried just fine. Now it goes through ''moods'' but I've noticed that the door switch and the overheating are correlated. Whenever the door switch works, the dryer will overheat. Whenever the door switch doesn't work, the dryer doesn't overheat. Any ideas about what's wrong?
5 Suggested Answers
  • 958 Answers
SOURCE: whirlpool dryer won't run
you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Posted on Feb 06, 2008
SOURCE: WILL NOT START. LIGHT ON BUT WILL NOT START
Check the thermal fuse, located on the right side of the heater housing. If bad order LA1053 kit.
Fair warning it's a real patience tester to install correctly
Posted on Oct 16, 2008
meBNme
  • 334 Answers
SOURCE: my maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Posted on Oct 20, 2009
  • 2180 Answers
SOURCE: maytag performa dryer model pye2300ayw, what
doesn't matter,it's either good or bad,when you touch the meter to it if it reads 1 and doen't move it's bad if you get any reading it's good,if the dryer is loaded with lint in the duct that the lint filter slides into and the vent line is blocked it will keep popping on you, clean out the dryer,number one cause for popping the thermal fuse
Posted on Feb 22, 2010
Can I reverse the door swing on my Maytag Performa dryer>
http://www.maytag.com/-[PYE2300AYW]-1109316/PYE2300AYW/
Here is the link to the owners manual. This feature is not mentioned. Look at the molding in the metal case of the front of the dryer. See if there are identical moldings for the door and latch on both sides. If not, no. Only alternative is to get longer connection hoses and swap washer with dryer left to right.
Dec 24, 2014 | Maytag Dryers
WHY MY MAYTAG DRYER PYE2300AYW WON'T START
Test the thermal fuse on the side of the heater housing. It should read closed for continuity. If open, you will need to replace the kit. Here is a link to the kit you need.
Oct 30, 2012 | Maytag Pye2300ayw Dryer Door Switch...
I have a Maytag Performa model #PYE2300AYW dryer. The issue I'm having is the dryer stopping all together midway through the drying cycle. You can get it to start back up by pushing down on the selector...
Yes, you can have a few different issues going on with your dryer and it may be hard to pin down. 1. You may have a intermittent door switch. I've seen this many times. 2. You may also have a motor that is tripping it's overload. 3. You also may have a timer issue. This may be difficult to fix on your own so you may want to call a pro. If it was me, I'd check the door switch or replace it. If it's not that, you may want to consider a new dryer due to the high repair cost. Hope this helps,
Jul 31, 2010 | Maytag PYE2300AY Electric Dryer
Dryer stopped running with 30 minutes left and will not restart. Maytag Performa PYE2300AYW
Reset the circuit breaker for the dryer. Allow the motor to cool, It has over temperature protection that will shut down the motor.
The belt that turns the drum may have broken. I am not sure about this model, but most dryers have a limit switch on the base of the dryer next to the motor that shuts down the dryer when the belt brakes.
Dec 15, 2009 | Washing Machines
I have a maytag performa electric dryer that's giving out no heat. model# pye2300ayw. what do I do?
could be three things. 1st) 240v should enter the unit. if 120v is missing then the unit will run but will not heat (on an electric dryer).
2nd) the thermal cut-off is not showing continuity and therefore not allowing voltage to travel to the element. 3rd) could be the element itself not showing continuity.
Jul 14, 2009 | Dryers
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
Pye2300ayw Dryer will not start. I think it is a bad door switch. How can a confirm this?
Change your thermal fuse first. when thermal fuse goes bad either the whole dryer won't run or the heat element won't come on. Check out item # 3344 at www.repairclinic.com/Appliance-Parts?s=t-pye2300ayw-%3d%3d&z=100 If your thermal fuse is bad there will be no continuity through it.
Mar 01, 2009 | Maytag PYE2300AY Electric Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
