Question about Thermador PG304BS Gas Kitchen Range
Error code "43"?????
Getting error 43 from thermador stove/oven, can you please help to tell me what this means, and how to fix it?
Thanks Marty for the info on the sail switch. We experience the same error code 43 problem. Seemed like the sail switch was stuck in the back position and didn't come forward when the fan started. So I bent a metal coat hanger and used it to pull the switch foward to "unstick" it. I tested the oven turning it on and off a few times and made sure that the switch moves forward with the blower fan starting when the oven was on, and moved back when the oven was turned off. Should be obvious, but make sure the blower is not running and the oven is turned off before you stick the wire hanger back there. A pretty quick and easy thing to try before calling the repairman.
error code
Posted on Dec 31, 2011
  • Alan B Nov 29, 2016
    Your pic made the difference! Thanks!
I got the error code 43 on my Thermador oven and after much expense I learned it was something I could have fixed myself. First, the concept: there are two cooling fans at the back of the oven that draw air in from around the oven and blow it over the circuit boards that are underneath the burners. You can hear the fans and feel the air coming out the front of the oven above the door when the oven is turned on (not the range top). This protects the circuits from overheating. In front of each blower is a "sail switch", a little switch with a lightweight metal rectangle attached. When the fans are blowing (any time the oven is on), it pushes the sail against the switch, closing it, and notifying the oven that the cooling is taking place. If the switch doesn't close, the oven thinks the fans aren't working. Also, if the switch remains closed after the oven is turned off, then the next time you turn the oven on, it will also give the 43 error code. This is to avoid giving a "false positive" reading in case the sail switch gets stuck in the closed position. So: first visually check the fans and sail switches. Do they close and open when the fans go on and off? They may need to be cleaned a bit to remove grease and gunk. Also, some of the switches are installed at an angle that prevents the switch from opening up again when the fans go off, causing the "fail safe" error. Finally, if a switch is broken, you must replace it. But its an easy job, once you pull the oven out.
Posted on Oct 25, 2011
  • vito Oct 02, 2013
    amazing i had a techian coming by i moved the sail switch back and forth and it worked again just saved myself at leasr $200 thanks guys
Cooling fan error
Posted on Dec 27, 2009
  • kerrijanocha Jun 09, 2011
    so do we need a technician to fix, and is it worth it to fix this. I've had this stove about 3 years now and I HATE it. It's a replacement of the same one that we had so many problems with they finally replaced it ( after a year of 7 problems, this company s@#$cks) any suggestions?
We have a Thermador PDR304ZS and had the same issue with the range turning off after several seconds and the blinking blue lights (4 3 error code). Marty's and KCW118 fix explanations and photo are awesome. I carefully grabbed the "sail" switches (metal rectangle in front of each fan) and moved them back and forth many times until I could hear the switch click with each movement. I turned on the range and it stayed on! So helpful - thank you! My wife had just called and service tech was ordering parts to come in a few days. Wife is VERY happy. THANK YOU!
Posted on Nov 29, 2016
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
I'm getting error code AM71 UI75 EEKGO-097 on my kitchenaid stove. The oven is not turning off unless I unplug. Please help.
I'm not sure exactly what that error code means, but being a technician I can tell you the control board and the oven sensor need to be replaced. The control board simply because it tells the oven what to do and when to do it, the sensor because its a rule of thumb because the two work hand in hand and because its a cheap part and with the situation has more than likely taken damage of some sort.
May 07, 2012 | KitchenAid Stove / Oven / Range Infinite...
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Thermador P304CS error code 4 preheat blinks then 3 heat blinks
I wanted to post this up in case someone has trouble finding an answer and what worked for me. I found somewhere else that the 43 code (4 preheat;3heat) blinks was specific to the cooling fan or the temp sensor. I had started to remove the temp sensor off the back wall of the oven but was unsure where the wire ran to. There is a specific Ohm value it should have around 1080 I think (not 100% postive).
What I found during that search is what solved the oven problem for me. On the top of the range, if you pull off the grill grates and remove the center stainless cover you can access under the burners. You can do this without removing any wires or hardware. In the back of this area is a small cover held in by 4 screws. Remove that. Underneath it is the cooling fan switch. It is a mechanical switch that when the fan kicks on it pushes a metal sail that then causes a connection in the switch letting it know the fan is operating. This switch had a little bit of corrosion on one terminal but it is also prone to getting dirty. Clean it off and try to restart the oven. The sail should move forward and the switch makes connection. For me once it was cleaned and any corrosion cleaned off, my oven worked just fine. This is a pretty easy check with the 43 code since it does not involve a lot of invasive work. Hope this helps someone.
Mar 07, 2010 | Thermador Kitchen Ranges
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Flashing Lights on Thermador Oven/Range
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Jan 31, 2009 | Thermador PGR366 Gas Kitchen Range
Could you tell me what year this model thermador gas top 6 burner
Thermador PRG stove is build between 2001-2003, $5, 000 new.
depends on the condition of the stove, and the oven. of cause, it is hard to say how much without testing it out. It is like buying a car. need test drive.
Jan 06, 2009 | Thermador PGR366 Gas Kitchen Range
Blue blinking lights
I'm Neil
No problem
Check your Manuel
Call The Manufacturer you have a warranty!
Please rate my solution!
Jul 22, 2008 | Thermador PGR366 Gas Kitchen Range
F 34
My Name is Don from Mr Fix it Applaince in baytown texas. I have seen this F34 error as well and may have a solution for some of you... According to a Thermador error code book for a C301bs/03 single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the controlboard that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow, I found Two of them on the bottome of a double oven thermador a few moths ago.. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.
Mar 10, 2008 | Thermador C301U Electric Single Oven
Thermador PG304BS Gas Kitchen Range Logo
2,496 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
