Question about Solis Coffee Makers & Espresso Machines
Led reads "ventilate". What do I do?
Ventilate
  • 1,089 Answers
Hi
Ventilate means that you need to run water through the system.. Open the knob on the right side of the machine if it a Master 5000, or push the right button and light it up, then open the knob if its a Palazzo.
Posted on Aug 02, 2009
My 32inch led aoc tv getting overheat on left side of the screen . Why does it happening . I am feeling afraid to on . Please give me solution
Your monitor's power supply may be on the left side. Ensure that your monitor has plenty of ventilation so that it can run cooler. Poor ventilation can cause early failure. Electrolytic capacitors can be damaged easily from too much heat, causing early failure. This is the same for your computer and the brick power supplies for electronics. Electrolytic caps are a common failure component.
Sep 23, 2015 | AOC Televison & Video
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
How do you deal with a Lamp fan problem
the projector is turned off for two reasons ventilation or power supply has to prove who are working on special turbine
Jun 25, 2014 | Optoma Technology Optoma EW1691E 3000 ANSI...
Schematic for vizio vbs210ws
According to the user manual, the fourthj LED flashing (Error D) means that a thermal (heat) shutdown happened. If Error D, Thermal shutdown, is indicated, turn off the Sound Bar and verify the ventilation slots in the Sound Bar are clear, the Sound Bar has proper ventilation and is not being operated in an environment
that is too hot. If these conditions exist, reduce the volume level for the particular source content being played. My bar did this and I left it disconnected from the Ac power a full day , and it powered up the next day.
Aug 30, 2012 | Vizio VSB210WS Soundbar
Ventilate
Hi
Push the button with the drop below it . That should remove the ventilate message.
Jan 08, 2010 | Saeco Royal Cappuccino Espresso Machine
Water LED flash
Hi
Try pushing the water button on the right ( it should light though dim ) and then open the steam knob.
Apr 01, 2009 | Solis Palazzo Espresso Machine
Ventilate!
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website: http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit www.CeriniCoffee.com
May 29, 2008 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
245 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
