Question about Panasonic Toughbook T8 PC Notebook
I WANT TO UPGRADE MY 10GB HARD DRIVE MYSELF!
PANASONIC TOUGHBOOK CF71
  • yoldan930 Aug 05, 2009
    okay thanks~ so I really can just use a external harddrive instead of going inside the laptop? If so what kind do you recommend thanks
    thank you
  • 453 Answers
Http://www.archmemory.com/ram.cfm/Panasonic-Memory-Toughbook-71-CF-71-Pentium-III-160GB-Laptop-Hard-Drive-for-Panasonic-Toughbook-71-CF-71-Pentium-III-16967-94413
Kindly follow the steps before installing the new Hard drive.
1. Back up all data in the previous hard drive.
2. Make sure you have an OS system disk with you so that you can install the OS in to the new hard drive.
3. Remove the older hard drive. Place the new hard drive in its place.
4. Press F2. The BIOS menu will open up.
5. Select CD/ DVD as the first boot device.
6. Place the CD in the drive and turn off the laptop and turn it on. The system will boot the OS from the CD and install the OS in the new hard drive. The progress will be menu driven so need not worry about any settings later.
7. It might ask you to format the hard drive once again and the proceed with the installation. That must not be an issue. You may proceed with the same.
8. Once the OS is installed it will ask for username settings and date and time and language settings.
This will keep you laptop ready to use but you need to upgarde the drivers.
Visit the manufacturer's website and upgrade the drivers.
I can understand that a 10 GB HDD will not be sufficient to install any programs but woul;d recommend to use the same and use an external hard drive and uninstall the programs which you feel you may not use and back up the software in the external hard drive.
Kindly note that there is no way to transfer OS from the older hard drive to the newer hard drive.
Posted on Aug 02, 2009
  • Sai Kiran Camsarapalli Aug 05, 2009
    I would recommend a portable one if you need to carry data anywhere around. But if you are not going to carry data around then you can go for a one which has a power cable.
    I would prefer you choose Western Digital (WD)
    WD Passport elite - 320 GB -Portable
    WD My notebook Essential Edition - 500 GB or 1 TB- USB connect and can be connected whenever you desire but comes with a power cable to drive the external HDD. Hence not portable.
    If not this one then I would prefer you to go for Seagate as the next option.
    Hope this helps :)
How to wipe clean CF-19 hard drive
If the Panasonic Toughbook CF19 has a Hard Disk Drive,
then you should be trying to wipe it by booting from an
external USB Optical (cdrom) drive.
You have to enter the BIOS by pressing the F2 function key,
and set USB CDROM as the first bootable device.
Then save and exit the bios.
The external optical (cdrom) will now boot
with the proper bootable media.
If you have a HIREN bootable CD then one of the
tools will allow you to WIPE and RE-FORMAT the
internal hard disk drive.
Good Luck.
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Jun 25, 2014 | Panasonic Toughbook CF-51 Notebook
Sata drivers xp
For any Panasonic Toughbook built after the year 2005,
if the Toughbook uses a SATA hard drive instead of an
IDE hard drive, then you will need to use Windows XP SP3
(Service Pack 3) instead of XP SP2 (Service Pack 2).
The XP installation CD for SP3 automatically includes
SATA drivers and you do not need any extra drivers.
That is it. Good Luck and Best Regards from:
Richard, Montreal Based Panasonic Canada Authorized
Toughbook Dealer since 1989.
Jan 22, 2014 | Panasonic Toughbook CF-30 Notebook
Swapped out hdd cf-52 nothing happening
When you swapped out the Hard Disk Drive
of the Panasonic Toughbook CF52 it is very
importatnt that you did not "hot" swap the HDD
but that you turned off the unit with a full shutdown
and unplugged it as well.
Once you removed the Hard Disk Drive (HDD)
I am assuming that you replaced the drive with
another drive that had a proper operating system
already installed. If not, then of course nothing
happened since you replaced the HDD with a blank
or unformatted HDD.
One way to verify if the replacement Hard Drive
is recognized by the Toughbook is to go into
the BIOS by pressing the F2 function key and
checking the size or capacity of the replacement
Hard Disk Drive. If it shows the proper value,
then the HDD is recognized at the Hardware Level.
If it shows HDD as None or Zero then the replacement
HDD is NOT recognized and you have to try a different
drive which is functional.
Good Luck!
Regards,
Panasonic Canada Toughbook Authorized Dealer since 1989
Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Windows xp installion does not see my hard drive on Panasonic CF-74
Just a thought but are you using XP Pro SP2 or SP3?
In my experience, only XP Service Pack 3 will see your
Hard Disk Drive, not XP Service Pack 2.
Good Luck!
Regards,
Jan 30, 2013 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
Panasonic Toughbook won't load Windows XP CD
You can check to see if the hard drive is dislodged, but other than that I don't know what to tell you. If you know the drive is functioning correctly then your motherboard is probably dead.
Jun 25, 2012 | Panasonic Toughbook CF-30 Notebook
Install hard drive,panasonic toughbook cf-48?
where is the hard drive and where can i buy one !
May 11, 2010 | Panasonic Toughbook 48 Notebook
Panasonic laptopcf71
You need to get the correct Video Driver and install it for your Laptop, go to manufacturers web site and download the correct driver for your model and install.
Jan 25, 2010 | Panasonic Toughbook 71 Notebook
I have a panasonic cf-51 with 40-gig drive. I want to upgrade the drive with something at least 160 gig. Do you have any drives available? What spec should I be looking for?
Basically, any EIDE interface hard drive will work, if you buy a new drive, just make sure to use the included software to boot the laptop up with in order to initialize the new disc and make it useable on your system.
Sep 27, 2009 | Panasonic Toughbook CF-51 Notebook
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
See all Panasonic Toughbook T8 PC Notebook Questions
Panasonic Toughbook T8  PC Notebook Logo
53 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
