Question about Samsung DVD-V4600 DVD Player/VCR
Samsung DVD V9700
Just bought a VCR/DVD combo for the den's Samung Flat panel tv. Hooked up the unit exactly as the manual says, cables out from the STB to the VCR, cables from VCR to back of the TV, and nothing. No image from the VCR.
WHen we use an old Phillips Modulator in between, at least we can get a VCR image, but after about five minutes, the image keeps switching from TV to VCR.
  • CharStar Apr 28, 2008
    The VCR and DVD was working just fine, when I wanted to play a DVD and switched over to DVD the light shows up on the DVD side but the display screen still says VCR. When I have a DVD disc in and the DVD light is on it will say No Disc found, because the display screen is still saying VCR. I had played a DVD and the next time I try to play another DVD this is what happened. Hope you can help!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Double check the cables. if it has a tuner, use that
Posted on Jul 15, 2010
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have a Digistar flat screen TV mod # LC32U5D Was a demo in Walmart - came with no manual - Have a vhs/dvd combo unit hooked up to it with a 3wire set up - can watch TV no prob - can watch dvd or vhs no...
you have to send the video and audio from the tv set to the inputs on the VCR recorder (it should be labeled "IN" there will be one yellow, one white (or black) and one red connector. without these cables hooked up, your recorder has nothing to record from.
Mar 10, 2011 | Televison & Video
Can anyone tell me the code for toshibe combo unite . i have a ge remote
Try code 0394 or 0924 or 0260 or 0358 or 394 or 902.
It depends on exactly what kind of combo unit you have - tv/dvd - tv/vcr - dvd/vcr.
All GE Universal Remote User Manuals can be found at the following link:
http://www.jascoproducts.com/support/universal-remote-codes.asp
Good luck and please comment back and RATE if this was helpful.
Feb 04, 2011 | Televison & Video
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
Dec 18, 2009 | Panasonic Televison & Video
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
I'm trying to get my dvd recorder and vcr hooked up to my new flat screen tv. How do I connect them and what channel do I put my tv on (flatscreens don't have channel 3 or 4) to recognize the dvd recorder...
DVD players do not connect using regular cable connections Your flat screen TV should have separate Audio and Video connections. These are the connections that you should use to connect your VCR and DVD player. If you have a combo unit, that is a single unit that has both DVD and VHS in one box, you might be able to get your VCR to work on the cable connection. However your DVD will not be able to work as the cable connection doesn't allow enough information to pass through. If you go to your local Audio Video store and tell them what you want to connect they should have the cables you need for less than $10.00. Good luck.
Sep 15, 2009 | Televison & Video
Poor viewing with VCR
how do you have the combo connection and dish network hooked to the tv ? if you have an s-video , yellow RCA jack video or component video hooked to the same input then it will act this way, because two inputs cannot be on the same video input # on the tv.
is this what is happening? or how are you connecting it?
Jan 04, 2009 | Samsung DVD-V4600 DVD Player/VCR
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Samsung DVD-V4600 DVD Player/VCR Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
