Question about Pioneer Televison & Video
Probs with dvd connection to plasma. the picture is coming through but not the sound...i guess i do not have plugs in the right place but cant work out where the prob is...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would be dependent on how the DVD is connected to the plasma TV.  On most instances, an additional pair of RCA to RCA (red & white) cables are required for the audio.  This is in addition to the yellow (composite) or red, blue & green (component) cables for video connections.
It must be pointed out though that there are other connection methods depending on the available jacks on both the DVD and TV such as ANT/RF, HDMI, digital audio.  Postback with the model numbers of the Pioneer and DVD player.  Additionally, please describe how they are interconnected, the number & colors of the cables and from what jacks to what jacks.
Good luck and thank you for asking FixYa.
Posted on Aug 02, 2009
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
Dvd player connected to panasonic viera. picture has blue skin tones and picture isn't centered
I always try the simple things first. check the connection. if hdmi .. then try a differnt cable.
It almost sounds as if one of your connections is plugged in the wrong place.
On component.. red to red, green to green and blue to blue .. then the extra red and white go to the video part .. also may want to check the tv manual - sometimes they share those connections with regular rca connection and easy to plug in wrong place.
Rca connetions - Yellow is video - red and white audio.
S video - one big plug and then red and white audio - make sure the big plug is fully in on both devices - I've seen similar things with s-video plug not fully connected on one end or the other.
Good Luck,
Bill.
Nov 29, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Tv will not come back on,inserted a DVD and tv went blank, no sound, no picture
prob your choice of dvd movie, tv's pouting right now, just a temp prob, will turn its self on when finished with tantrum
Nov 26, 2009 | Akai LCT3201TD 32 in. LCD Television
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
No tv picture
my less than 2 yrs. old hardly used Samsung plasma is turning off automatically for no reason within 10m minutes of watching. What could be the problem??????????
Mar 16, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Black Screen
You really need to check your video connections. It sounds like you have the sound cables connected properly, but not the video cables. Are you using the component connection (blue, green, red, white, red) or RCA (yellow, white, red)?? Make sure the color coded ends are plugged into the right places. If you've done this then your display is shot and you'll need to get your warranty paperwork out or call a local repair shop. Good luck!!
Sep 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sound system
check your wire connections they could be faulty if you are doing the connection properly.
May 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Trying to connect dvd player
You will have to connect your DVD player to the plasma TV, not the cable box. The cable box (or most cable boxes) have video outputs only. The same is true for the DVD player: it outputs the video to the tv.
Look in your DVD manual for scenarios for connecting your player to the tv.
Mike
Dec 06, 2007 | Panasonic DVD-S27 DVD Player
No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Jan 04, 2007 | Denon AVR-1706 Receiver
Televison & Video Logo
20 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
