Question about Tomtom GO 910 GPS Receiver
Tom Tom ONE Version 3
My Tom Tom keeps closing down the screen after 10 seconds or so but is still on. If I touch the screen it resumes briefly. The Tom Tom is still on with the blank screen and provides voice directions with the screen blank. I have only had it several weeks. On some occasions it might last for say 10 mins or so and then switch off.
I have checked the Planning Preference screen and the Route summary screen is marked No not to turn off after 10 seconds.
Any solutions would be appreciated.
tom tom starts up and remains on the tom tom start up screen. tried many times to re-start by letting battery go flat. Once it locks up the power button is non responsive
Found the problem being a corrupt file in the unit. Connected it to Tom Tom and deleted the file. The unit then started and the system replaced the file. Only problem cant remember the file name...found this solution on the web
Posted on Apr 14, 2008
  • 504 Answers
Have you tried resetting the unit? Does it do the same thing after being reset?
Posted on Jan 21, 2008
2 Suggested Answers
SOURCE: Tom Tom ONE Version 3
Radioland I have the same issue, it take almost an hour to DL with 1.8MBPS DSL, then I get a system error when it goes to install on the GPS
Posted on Nov 25, 2007
Why does the power window button blink on and off and the automatic feature doesn't work in the 2008 Toyota Sienna?
Anytime the batteryterminal has been disconnected, please initialize the driver's door power windowand front passenger's door power windowafter reconnecting the batteryterminal.
With ignition switchin the "ON" position, do the following:
1. Push down and hold the driver's door power windowswitch to completely open the window.
2. Pull and hold up the driver's door power windowswitch until the window closes.
Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
At this time the power window switchfor the passenger's door windowshould be blinking.
4. Push down and hold the passenger's door power windowswitch to completely open the window.
5. Pull and hold up the passenger's door power windowswitch until the window closes.
6. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
Feb 09, 2016 | Toyota Cars & Trucks
Hi my name is mike and have a serious problem with my playstation 3 well my system froze up in the middle of a game so i turned it off to reset it and now a red screen comes up and says a serious error has...
Try to start to the system in safe mode to check if this will resolve the problem.Safe mode is available to PS3 system software version 2.60 or later. To do the safe mode follow these steps:
  1. Verify that the power indicator on the PS3 system is solid red, and then turn off the MAIN POWER switch.
  2. Turn on the MAIN POWER switch, then touch and hold the power button.
  3. Keep touching the power button even after you hear a short beep after 5 seconds.
  4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
  5. Touch and hold the power button again.
  6. Continue touching the power button even after you hear a short beep after 5 seconds.
  7. Release the button when two short beeps are emitted after 7 seconds.
  8. As instructed by the on-screen message, press the PS button to start up in safe mode
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
When i connect my ipod touch all it does its a little sound and then like 9 seconds after it does the same thing but itunes does not recognize my ipod and i dont know whats going on can someone help
Try restoring your iPod. Firstly, make sure you have the same (or above) version of firmware on your computer somewhere. By doing the next step, you need to know that all data and settings will be erased from your device. If you are OK with this, put your iTouch into DFU mode by:
1. Plugging your device into your computer.
2. Holding down the power button for 3 seconds.
3. Without releasing the power button, hold down the home button for 10 seconds.
4. Release the power button, but keep holding the home button for 30 seconds.
Next, go to the iPod Touch panel in iTunes, and click on the "Restore" button. Now follow the on-screen prompts.
If you want to restore your firmware to a specific firmware (advanced users), shift-click the "Restore" button and select an ISPW firmware file to update it to.
Jun 19, 2010 | Apple iPod touch
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
I used my tom tom cig lighter power cord to power
I think it destroy. The tom tom might of use to much power, and toasted the nuvi.
Nov 21, 2009 | Garmin GPS
My tom tom one gps receiver changed over from english to german without me doing anything. it clicked for 10 seconds when I turned it off and was in GERMAN when I turned it back on..resetting the unit does...
Do this whilst it is disconnect from a PC
Whilst it shows a map display touch the screen once.
Select the icon that looks like a spanner / wrench
Use the rght arrow on the display until you see a bunch of flags. (if you shoot past it just keep going until it comes ound again)
Touch that and select the correct the correct flag / language.
Sep 23, 2009 | Tomtom ONE GPS Receiver
Error (13) in itouch keeps showing when restoring, HELP!!!! how can i fix my itouch out of this freezed screen displaying a cd and usb port.....PLEASE!!!
From Apple Website 1. Restart your computer (yes, you have too)
2. plug in your ipod touch (it should have the usb cord and itunes picture on the screen)
3. open itunes.
4. itunes will recognize the ipod. just ignore the message, and then hold down the home and hold button (on the top) for about 10 seconds, and after you count to 10, release the top hold button, but still holding home.
5. itunes will pick up the ipod, and once it does, release home.
6. Now click restore, and everything should work fine.
(if problem persists, try turning off firewall, and close all other programs)
Sep 14, 2009 | Apple iPod touch
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Tom Tom Touch Screen
While l was cleaning my tom tom 300 touch screen, some of the cleaning solution got in between the glass layers and I now have a spot that keeps moving. my question is there any way to open this up and dry this out or is the screen toast. Thanks mukat
Jan 14, 2008 | Tomtom GO 300 GPS Receiver
I am having the same problem only I am trying to with mine only I am trying to update my guarenteed map. I have DSL and usually have no problem but it is taking over 3 hours to even attempt the download then I get a system error.
Nov 23, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 910 GPS Receiver Logo
191 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
