Question about Whirlpool Dryers
MODEL GE/GQ9858J dryer runs about 5 min. or
MODEL GE/GQ9858J dryer runs about 5 min. or less.Starts beeping,then shuts off.Then timing knob turns to off by its self.
Dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Posted on Mar 18, 2011
Dryer starts but after a few seconds shuts down
In the last 6 months, I have fixed 3 dryers with your symptoms. In each case, after taking the dryer completely apart, I found it plugged up with a huge amount of lint. This lint was not caught by the filter screen, it had collected all over the inside of the machine. It required dismantling the machine completely to clean,. Each dryer then worked fine.
Be blessed.
Jan 03, 2014 | General Electric Profile DPVH880GJMG 7.5...
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
I have a GE/GQ9858J dryer. It does not turn on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Whirlpool GEQ8858J Dryer
The dryer will run for 5 to 7 min then shut off come back in about 3 min it will run then the dryer will do it over and over again untill it will not trurn on
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | GE DWSR463EGWW Electric Dryer
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
My GE AC starts to beep when I only turn it on for a while
Probably a bad sensor. Remove the sensor and clean it good or replace it. Todays newer stuff relies on a sensor to tell the beard what the conditins are in the house. The board sends a small dc voltage through the sensor and measures the sensor. Changes in temperature cause the voltage to fluctuate and this tells the brain when to shut down the machine. Long story short the sensor thinks the house is cool enough. Less than 5 bucks a sensor is easy to change out. It has a quick connect, check it for corrosion, with any luck all you need to do is clean it up.
Jul 17, 2009 | GE Heating & Cooling
Power Working fine but keeps shutting off
Hi jenniferlahm,
This type problem usually shows it mean head when your motor is going bad. The motor will run for just a moment then it gets really hot and shuts off till cool. I bet when you start the dryer you hear a unusuall humm as the motor starts. If you are not hearing a hestating humm as it starts then the problem may be elsewhere. Other possible problems that casue this would be. the tub rollers. To check the rollers reach inside and try to turn the tub with your hand. you should be able to turn the tub. if not you may need new rollers, or pads. Good luck and I hope its not a bad motor, but if it is let me know and I can have you one there in no time.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Sep 24, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
204 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
